Home > Technical (L322) > FBH Guru - French Mike.
JLS
Norway
Hi guys!
Could somebody Pm me the mail address to Mr. "Guru" French Mike?
I live in (cold) Norway and the FBH is often used in winter time... I noticed a few weeks ago that the water temp gauge didīt reach normal (vertical) level. I know that this is not a main job for the FBH Wink , but in the search of solving this problem, I found out that the FBH didīt work!?! And searching on internet, I found that French Mike has a lot of experience on this Webasto Thermotop C used in RR (among others).
Looking forward to hear from you!
Thx
JLS
Post #368900 25th Jan 2016 10:51pm
Temp gauge problem is more likely a thermostat issue (either main thermostat or EGR thermostat).
French Mike lurks on the Rover 75 forums if I remember correctly. .
Post #368917 26th Jan 2016 4:09am
JLS
Norway
Thx for quick response, Joe90! I will dive into the Rover 75 forum for a search for Mike Very Happy
Regarding the temp problem I thought it was the main stat also. But, after a bit of struggling to reach this son of a... I saw that it looked normal. Confirmed with the classic boling-test. It opened as it should, around 88-90dgrs C. After a bit of a shock there, I found the cooling routing in the WS.maual. I then discovered the second stat in the EGR, so I will renew that one as well.
X fingers.... Thumbs Up
(I have also learned that there is a stat in the oil/watercooler for the g.box, but that circuit is not routed through the radiator, sp that one I leave as it is...)
Post #368927 26th Jan 2016 8:40am
Have you considered the gauge may be reading correctly and the engine is being over-cooled.
Diesels are notorious for running cool even in warm weather, enough cooling is often provided by airflow over the cylinder block. I would think this may well be the case in Norway.
I would be inclined initially to remove the cooling fan and see what happens, it certainly won't over-heat.
You could also consider blanking off part of the radiator, old fashioned idea but it works.
Post #368933 26th Jan 2016 9:29am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
This post has been edited by the site administration team: email address removed from public view
Post #368942 26th Jan 2016 10:53am
JLS
Norway
Thx, PaulB. Iīve got in contact with him already. Thumbs Up
Post #368961 26th Jan 2016 2:18pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
As Joe90 advised have a look at the thermostats. On my TD6 I had the same issue, car never getting up to temp. On advise from this forum I took off the EGR thermostat which is easy enough and blew through it. It was stuck open so got a new one and problem solved. Even got a slight improvement on fuel consumption so should pay or itself in a couple of years. A tip, I picked up a very cheap EGR Thermostat for a BMW which had a different end for the hose connection, luckily the ends are interchangeable so was able to swap over
https://www.youtube.com/watch?v=ZhtfKliAkiU 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #369011 27th Jan 2016 3:42am
JLS
Norway
Thx, Wayneg. I bought the EGR-stat at a BMW-dealer and saw that the end was different after buying it... Nice to have confirmed that its possible to swap the ends. I havenīt had time to investigate this yet Thumbs Up
Post #369036 27th Jan 2016 1:46pm
Cool I'll have a look at this when I replace my lower hose! Is it as simple as if you can blow through it at all then it's dying?
If it's purpose is to cool down exhaust gasses would it possibly also highlight a stuck egr valve if it's causing he temp to stay cold as otherwise t would be adding heat to the cooling system? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #369113 27th Jan 2016 9:31pm
wayneg
You pull the big C clip thing out to release the end, there is a big spring behind so be careful. A fair bit of pressure to get the replacement end to seat against the spring before you can replace the C Clip. The other thing is if you watch the Video he makes it look simple to remove the hose to get at the bolt at the back, Not quite the same on the TD6. If I did it again I would have a jubilee clamp ready and cut of the spring type clamp to keep things simple. Still very straight forward though.
Kingpleb, if its stuck open yes you can simply blow through to check. If you think the egr is stuck why not fit a blanking kit and be done with it. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #369139 28th Jan 2016 3:14am
