Home > Technical (L322) > very loud under acceleration
ian
United Kingdom 2002 Range Rover Vogue Td6 Rimini Red
Hi all
I have recently come from a tdv6 disco to a td6 rangerover, and have been a little surprised at how loud the td6 is under accelearation. I first thought hole in the exhaust, but it is real quite when just revving the engine. it sounds more like a big v8 revving whoch is not what i expected.
ant body any ideas why it is so loud?
Post #368738 24th Jan 2016 9:01pm
mjdronfield
Mine was noisy when accelerating, especially when cold, it was mostly engine or intake roar though, as it had a k&n filter on it, which makes it louder. Never noticed much exhaust though.
It def sounds more diesel like than the 2.7 in the Disco, but then the engines must be nearly a decade apart development wise.
Not too bad when rolling along, but from a standstill you could tell it was very much a diesel. Good engine though. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #368740 24th Jan 2016 9:22pm
smighall
England 2005 Range Rover Vogue SE Td6 Buckingham Blue
Probably the viscous fan I would guess. Check it hasn't locked up.
Post #368742 24th Jan 2016 9:26pm
Viscous fan is a good call, mine on the disco is a noisy as a noisy thing when it's cold. Eases off after a little while though. There is nothing that can't be fixed with a hammer😜😜
Post #368754 24th Jan 2016 10:38pm
bear100
Hole in the turbo hose is quite common Thumbs Up 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #368766 24th Jan 2016 11:40pm
ian
hi, how do you check if the fan is locked up? the noise is quite loud under acceleration, but not there when cruising or just revving in neutral.. it sounds like a big performance exhaust but that all looks normal and in reasonable condition, with no obvious blow points..
Post #368975 26th Jan 2016 5:02pm
ian
Assuming i have located the correct hose (front left of engine, about half way down probably 2.5" in diameter, the pipe seems quite soft for an intercooler pipe. is it possible it is collapsing under acceleration, so causing the engine to strangle itself?
Post #368976 26th Jan 2016 5:04pm
unlikely to collapse itself as it is under positive pressure, when boost is applied. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #368979 26th Jan 2016 6:03pm
frikkadel
South Africa
If a viscous fan locks up, then would it not cool more than is required?
mine seems to be running all the time
Post #397102 22nd Jul 2016 10:23am
To check fan, get a rolled up newspaper and try to make confetti with it, start engine from cold and wait about 2 mins, then jab away, you should be able to stop the fan pretty easily if it's working, if you decorate yours and the neighbours drive then it's seized.... Thumbs Up Pete
Post #397161 22nd Jul 2016 4:43pm
