![]() | Home > Maintenance & Mods (L322) > Rear Washer Blocked |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
would not the washer water come out of said tube when the rear windscreen stalk is operated.. ... - .- -.
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
That's how I tested it Stan; by operating the steering column control why my lovely assistant watched the tube.
ah..never done mine so i dont know how much water should come out ..hopefully someone will come along and tell.. ... - .- -.
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Did you pull the pipe off the black elbow on the wiper motor or off the non return valve 2" further up the pipe?
Ta miggit.
It is possible to split the non return valve and clean it out...... it's not the ball bearing type.... it's got a knakered condom in it |
I tested the flow, sans non return valve and the expected vesuvius was forthcoming, ergo knackered non return valve. Ordered 1 at Barrats for the princely sum of £8 and change.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
have a look at the above fixes miggit put up, the seals go inside the motor and can be bought from a local supplier of bearings etc or off of eBay for a couple of quids. replace the seal follow the description, should take about 1/2 hour to strip and fix while you have got it off. works a treat, did mine on the 3.6 a while back and it was fine up until it was sold |
^^ Wot he said |
Here you go under £2.00 |
Well I bit the bullet and ordered a new motor from the bay for £147.50. Genuine Land Rover from the main dealer in Hull.
| All times are GMT |
