![]() | Home > General > Any bad points on the 5.0 FF |
Been perusing the Ads again and having a look at the 2010 Model 5.0 Litre FF's , have read about the common faults on the 3.6 TDV8's ( although i had one myself and never had any bother with it ) so was wondering if there is anything untoward to look out for on the 5.0 litre version or are they much in common with the 4.2 SC ( Also a previous car ) ...
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Sorry mick, I don't know much about the newer models, but,
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Not much help but...
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6829 ![]() ![]() ![]() |
From the anecdotal evidence Mick, doing little and often small mileage drives doesn't suit the diesel as much as the petrol.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Had mine nearly a couple of years Mick. 2010 MY 5.0 S/C. Like you, I only generally do short journeys so a diesel was not the right choice. Problems have been few and far between (kiss of death statement!). Adaptive Dynamics fault, well documented on here and a simple fix, TPMS errors when there isn't a problem (switch off with the IID tool). I did have the water pump fail last year in spectacular style with every conceivable warning light coming up, but I think that was hopefully a one off and not a common fault with this variant.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
i had the the L322 4.2 SC and the 5.0 SC - i had only some minor problems (been all solved under warranty) - and if you drive only a few miles per year like i did (6000) the 5.0 SC will be the perfect car for you |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
I'd like to respond in two parts. First the RR 5.0SC is fantastic. The engine feels perfectly mated to th zf6hp28 and the rest of the truck. It is a perfect amount of power for the truck distributed perfectly. There is so much torque in every gear you don't feel like you are driving a six speed, the tranny almost never needs to downshift for more power. 80mph up a hill, no problem. When you do need to downshift the truck is fantastic too. Driving over the Rocky Mountains on i70 you hit 10,000 feet and left lane speed is 65 MPH during the climb, my old Prius literally cannot go to the speed limit up such an incline, the rover can accelerate to nearly 100mph and it almost never needs a lot of gas/rpms unless you are accelerating to 100. The 5.0sc hp kicks in around 3.7 grand and it takes off, getting on to a highway at 80 or 90 mph just from the onramp is possible. Speeding around a trucker who seems intent to kill you, it is easy to get it past 110mph, a matter of seconds from normal highway speeds. This engine wants to be driven fast. It is a pleasure either cruising or going in the mountains where passing is a breeze, instead of a crap shoot.
Don't call it a TRUCK ! |
When it is over 6,000 pounds wet, and has 510 hp, and is taxed as a truck, what do you intend to call it? |
If you've got a spare 94k Mick, I'd go for the Sport SVR |
Mick, the 5.0 is a far nicer drive. The only place it trails the log burner is low down torque for towing. That's it, in every other way the 5.0 is nicer. |
In the fatherland it is taxed as a CAR ! |
2017 I've heard 50 HP boost across the range of 5.0SC tunes, so 600hp or so in the SVA and 550hp or so in the standard SC. They will get faster still. |
Section 179 - i am lost ? All my spelling errorz are belong to me!
