Home > Technical (L322) > Cornering lights
mjdronfield
Cornering lights
Bit of a daft question - how do you know if your car has cornering lights?
Mine has like a separate bit on the bottom outer of the headlight units but I've never seen any extra light when cornering....
Was it an option on the 2011 cars? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #369251 28th Jan 2016 10:28pm
You can see them clearly when you go round a corner - it's like switching the fog light on/off - there's nothing smooth or subtle about it.
Post #369252 28th Jan 2016 10:30pm
mjdronfield
Don't think I have them then.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #369253 28th Jan 2016 10:38pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Should see them on mine :
[/IMG]
Post #369259 28th Jan 2016 11:07pm
miggit
They haven't been disabled by a Stan, have they? Yesterday I couldn't spell Engineer... Today I are one!
Post #369267 29th Jan 2016 12:13am
Shocked mind control Shocked ... - .- -.
Post #369282 29th Jan 2016 9:21am
I think i read somewhere they became an optional extra in 2011my?
Post #369292 29th Jan 2016 10:00am
ebajema
If you have access to a Faultmate / IID tool you can check if they are disabled or not and then turn them on. It is very obvious when they do come on at night. I noticed them clearly on mine. I also noticed that the bulb is not visible from the outside (not that I tried looking at it from all angles but I did look at them). Maybe both your bulbs have gone.
Maybe ask your dealer or Duckworth Dan a favour and get them to print the build sheet. On my buildsheet they are not mentioned separately but the adaptive headlights are and I'm expecting all adaptive headlights to have the cornering lights. MY 2010 5.0 SC Galway green and sand interior!!
Post #369296 29th Jan 2016 10:21am
Eugene, they are LED on an 09> my’s sir Thumbs Up
Look closely and you can just spot the LED's Thumbs Up
Post #369297 29th Jan 2016 10:23am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I have them on my 2010 - very obvious at night to be honest - just turn your steering wheel to one side and that side light will come on...
Not sure if they are a function that can be enabled/disabled though Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #369308 29th Jan 2016 11:10am
they can on the pre 2010my FF's, you just take the bulb out Mr. Green ... - .- -.
Post #369311 29th Jan 2016 11:23am
Yes they can be enabled/disabled via CCF but! The correct lights need to be fitted to be enabled... Thumbs Up
Post #369324 29th Jan 2016 12:33pm
rangie_mike
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Just took some pics of my cornering lights off and on, note must be in Drive.
 Current : Range Rover 5.0 SC 2011 Orkney Grey
Previous : P38 4.6 Vogue 2000, Audi A4 Avant 2.5Tdi Quattro Sport, RR Classic 3.9 Vogue, BMW M535i, BMW 525e, BMW 2002tii, Austin Metro
Post #369383 29th Jan 2016 5:29pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I take it they all don't have them?
My 2010 doesn't seem to work.
Post #369404 29th Jan 2016 6:31pm
mjdronfield
Thanks gents.
I already have my build sheet. Will have a search.
From the pics, looks like they work when stationary - just turn the wheel in D.
Will test that, but pretty sure I don't on that basis..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #369420 29th Jan 2016 7:08pm
