![]() | Home > My Range Rover > My new '12 Autobiography (finally got it!) |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Hi and a warm welcome.
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
PM sent
Hi hello & welcome sir |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8117 ![]() ![]() ![]() |
For occasional use - I would recommend Thule roof bars
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Congratulations and welcome.
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 442 ![]() |
Nooooooooooooo
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Love the seats Good looking RR 2015 4.4 AB
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
nice Range keep the kit on it |
exalin Member Since: 14 Jan 2015 Location: Cheshire Posts: 69 ![]() ![]() ![]() |
I have a set of Whispbars that fit into the fixing points on the roof without having to break off the plastic flaps that cover them. They lock to the roof and are really easy to fit/remove plus very quiet at speed too.
bluehorseshoe Member Since: 29 Jan 2016 Location: Fairfield County, Connecticut Posts: 27 ![]() ![]() ![]() |
Thanks for all the comments.
Ok because you were concerned about clearance and your rear bumper is lower and it may be a bit longer than stock which makes ground clearance worse. The stock one also angles up a lot more (more ground clearance) 2014 FF Autobiography 5.0 SC
Croz1 Member Since: 28 Dec 2015 Location: Denver Posts: 10 ![]() ![]() ![]() |
Hi Bluehorseshoe - glad you made it over to this forum!
I've got no experience other than Thule.
If you want a roof rack that is actually
