![]() | Home > Technical (L322) > Car idles rough then revs drop and it stalls |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
What model, engine and year are we talking?
Choppergrino Member Since: 29 Nov 2015 Location: Melbourne Posts: 14 ![]() ![]() ![]() |
It's an L322 and yes it did run before.
Petrol or deisel? Size of engine and model year? These are pretty key pieces of info to anyone trying to help you.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
It's in his signature. plus "I am new to this forum and have stumbled upon it searching for info on L322 timing issues.
I'm aware a car is listed in his signature, but when he said his brothers I assumed it would be a different one. I have better things to do than search someone's previous posts to find the quote you found. |
Thanks for that. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
A quick check is connector on the throttle body which is easily knocked if climbing on the engine to get over the back and gives the symptoms you describe if not fully connected. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
MAF .? |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Enough fuel?
Thanks everybody for the posts.
Today I put new fuel in and and reset the ECU.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Air leak, maybe around where the inlet pipe meets the throttle body or various small pipes
Thank you holiday chicken I will have a double check.
