![]() | Home > Technical (L322) > External Temperature Reading |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
It does seem strange how almost all car thermometers read artificially high at least by 1 or 2 degrees.I have a couple of more accurate ones at home and the usual hot or cold days when people say it is [x] degrees today after driving their car when I usually have to correct them ! |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Anyone got any idea why this AAT sensor has now started reading - 40.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
easy to check the wiring to the sensor as it sits behind the front grill. 3 screws to take it off and have a look. sounds like its open circuit. There is nothing that can't be fixed with a hammerππ
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
If nothing has been disturbed then do a hard battery reset... Might just put things right? |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
Mine read -40 withe the sensor unplugged. |
Oups post by accident Eddie the eagle watch out π |
Hi chaps
Cheers Craig. Yep tried that. In fact it was working OK before I took the Battery off to charge it on the bench. I only did that because the car was not getting used much. I was getting between 20 to 23.5 mpg out of her on a steady motorway run to Wales and back at Christmas. Now it's down to 11.5 mpg. I know it may take a few miles to settle after a reset but not sure I can find Petrol stations close enough together to do that. LOL.
Pepi,
Cheers Declan have read your post with interest. Did you find a resistor that would give you a zero reading? Or any LR written calibration data. Saying what resistance the sensor should be giving. Also did you try a dead short test reading.
Hi Pepi,
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Had something similar last thurs when I changed the battery. Immediately showed as reading minus 40c !! Drove around for a couple of hours and the temp returned to what it should be, dropping a few degrees at a time. |
Thanks Declan
Thanks for that it will be good to see if it will sort it's self on mine.
