![]() | Home > General (L405) > Advice re factory misbuild |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
May will soon come any.....
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
I think that's a fantastic result - you get a newer car, for not much inconvenience |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Isn't there some way you can test drive your new car before you accept it, don't you get the opportunity to do what the dealer should have done, a proper PDI and highlight issues before you sign for it...??? Pete
JMDT Member Since: 10 Jan 2016 Location: Suffolk Posts: 60 ![]() ![]() ![]() |
You are right. Should have been picked up on the Pdi.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
I heard recently there is a nose weight limit on the deployable towbar which excludes many normal twin axle tin tents - might be worth checking if that your use. |
Ajac8. Thanks for tip re towbar. It is for a boat (6.5m RIB) so I will check weights. Good tip. |
It's the off road weight that's limited with the powered to bar - on road is fine as is nose weight - as long as 150-200kg is sufficient......
Thanks for that. My towing on road. But good to know. |
Got my replacement today... The sun roof blind didn't work properly, so left it at the dealer.. but soon resolved as something had been left in place that shouldn't have been (a shipping magnet in the centre of the blind) and they then drove it out to me. Saved me another trip but shame it hadn't been picked up as part of PDI. However, will have to take it back in to sort out the drivers door as the soft close does not work. On the positive side, got 9500 miles of "free" motoring in the original. It will make a fantastic used buy for somebody... |
It's great that they did the right thing re the mis-build - but you really would have thought they'd have PDI'd the new one to death before you arrived |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1175 ![]() ![]() ![]() |
Get some pictures up, i love the waitomo grey. |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
The driver's door soft close is disabled at the factory, and should be enabled during the PDI. It is a simple procedure to switch it on. The same oversight occurred with me. |
Paul - that's helpful to know. They did say it was a quick fix re programming... Current: L460 Autobiography D350 2023, Defender D240 HSE 2020, Defender 110 Adventure 2015, Defender 90 XS 2012, Lightweight Ser III 1975, Aston Martin DBS Manual 2008
Light is poor but here is a shot...
