Home > Off Topic - Other Cars > Finding a generic fit in pipe
Wonder if anyone can help at all,
I'm re routing the cooling system in a car and will be creating a new high point as part of this which I won't be able to get round. This means the new section needs to have a bleed nipple on it Sad
What I'm trying to find is a straight piece of rubber section but could be plastic or metal if needed as it won't be high pressure just hot(!) about 3-5" long and about 12-18mm ID that had a bleed nipple built into it or if not possible a way to easily fit a bleed nipple onto a section of silicone hose Smile
The only ways I can come up with is using something off an old Volvo or Peugeot from eBay or a breakers but as the other pipes will be new I'd rather not fit an old bit! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #370108 2nd Feb 2016 7:56pm
Weegie
Will, The Discovery 2 has a hose with a bleed nipple incorporated in the coolant system. It is used to bleed the system when replacing coolant. Don't know the dimensions offhand but a bit of research will turn it up.
Just a thought.
Alternatively these people, from whom I have had silicone hoses, do hoses to measure and might come up with a solution. I have found them to be helpful. http://www.derbyperformancehose.co.uk/ John
GAP iiD BT-Sold
Post #370110 2nd Feb 2016 8:06pm
Hi John,
Are you thinking of this pipe at all?
http://www.ebay.co.uk/itm/262227290241
Is the pipe your thinking of the same on all engines or just a td5? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #370168 2nd Feb 2016 11:10pm
Weegie
Not what I was thinking of. I'll try and get PN. John
GAP iiD BT-Sold
Post #370171 2nd Feb 2016 11:19pm
Cheers John 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #370174 2nd Feb 2016 11:24pm
Weegie
Will, The part no is PEH101080. Looking at it the part with the bleed off seems a bit larger than you are looking for? John
GAP iiD BT-Sold
Post #370180 2nd Feb 2016 11:42pm
And VERY expensive from memory Will...
My TD5 Bob needed one a couple of years ago and it was north of £70 from memory & around 1.5” across so maybe too big?
Post #370182 2nd Feb 2016 11:52pm
Thanks John
Yes a quick look it's definitely going to be a bit too big. Ideally it needs to be around the same size piping as the longest branch is from the main large pipe.
Thanks anyway fella 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #370183 2nd Feb 2016 11:53pm
Kerching Sad
There must be something out there in the market or am I going to have to get a but if stainless or copper and get something brazed on to sort it Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #370185 2nd Feb 2016 11:56pm
Weegie
Any use? http://www.carbuildersolutions.com/uk/blac...with-bleed or http://www.carbuildersolutions.com/uk/blac...with-bleed John
GAP iiD BT-Sold
Post #370211 3rd Feb 2016 9:53am
Cheers that's a great site John!!
Already favourited and compiling my whole list of bits from there including bends for the break into the circuit!!
Mercy Buckets indeed 😊👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #370366 3rd Feb 2016 8:00pm
