![]() | Home > Technical (L322) > What should battery voltage be while running |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Yes, sorry, I knew what you meant by the syndrome, but what exactly were you referring to as being so? Visiting from DISCO3.CO.UK
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I suppose that the best way of describing it is, Land Rover had to invent an average temp gauge, so that paranoid owners didn't constantly complain that the gauge was working correctly and showing the actual temp of the engine, and that it was going up and down like a yo yo |
Sorry if I've missed something obvious, but I'm still confused.
What was the "this" representing? The subject of the thread, the voltage accuracy, my comments, or something else? ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Your voltage also goes up and down, depending on what demands you are placing on the system, coupled with an inaccurate meter, and you'd be forever changing batteries. So my gauge says that it's got 14.0 volts when running, according to this thread my battery is fubar'd |
I not having a go, in fact I'm agreeing with your first statement, inaccuracy is the route of all panic ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Right, I see.
Indeed, I'd certainly not say that. Not sure how advanced the TD6 system is, but alternator output should rise according to the battery state of charge and temperature, so a higher voltage is usually indicative of a poorer battery. It's the standing charge reading from a battery that should be used to determine it's rough state of health though, not the alternator. ![]()
Exactly, just trying to make peeps aware of that (occasionally people come looking for help on Disco3/RRSport armed only with readings from the screen...). The voltage readings on the diagnostic screen, and as live data via the IID (which are a more accurate than the screen) have been discussed a few times on Disco3. ![]() To clarify my point on the multimeter/oscilloscpoe, the reason for this is not down to the voltage resolution, but rather the sample rate. A bog standard multimeter is too slow to pick up excessive voltage ripple and spikes, which could be the root cause of an issue. So an alternator might appear to be fine, when it's not. Of course, it's not the sort of equipment that most people, myself included, could justify the cost of! ![]()
No worries; never thought you were. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
Well after reading all your comments/observations I went out started the car and used the on board self test (753 one), and the reading was 13.5.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Absolutely we worry too much about what gauges tell us.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Old thread dug up again guys, finally changed my faulty FSR and with the crude voltmeter plugged into the cigarette lighter I'm getting 13.6 to 13.7 on it while driving, nothing higher than that?
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
14V or around about that mark (+-0.5V) and your battery will be charging fine.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Iv'e just checked all four batteries that I have (cars and van)
When you check voltage dont open close or move anything on the FF for at least 5 mins all the sodding computers need to get back to sleep.
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Plugged my ELM OBD2 in today and viewed the voltage using Torque Pro. 14.1 to 14.2 v while driving and 12.6v after a couple of minutes after switching off. |
