![]() | Home > Technical (L322) > Soggy Wheel Well |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
I thought my seal was fine, looked like new, but it wasn't. New seal fixed the problem, no more leaks.. |
mark g Member Since: 28 Dec 2015 Location: Shropshire Posts: 31 ![]() ![]() ![]() |
you dont look at the outer part of the seal, its the inner part where it clamps over the body shell lip, if you look around the edge you will see what look like swollen areas if its toast, hope that makes sense |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I would say it's your tow bar fitment , my boot filled up under the EAS compressor after I fitted the OEM westfalia bar.
