![]() | Home > Technical (L322) > OOps accidently clocked my RR! L322 TD6 |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
The dot is a visual sign to say that the dash cluster mileage doesn't match that stored in the BCM.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
The issue is that the cluster (and many other ecu's) can only be programmed from new. Once used , they are fixed.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
It was explained to me, that if the secondhand cluster is higher miles, than the old one, it won't clock up miles, until the car catches up with the displayes 'new' mileage, via the LCM. And maybe then, the dot disappears....
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Bloody computers not that clever are they. Wonder what the MOT garage will say when I go to have it tested its done -20k since last MOT!Complication could do without before I sell |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Have you spoken to someone like this?
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
The dot doesn't signify the mileage has been altered. It simply shows that a part has been changed in the LCM? instrument data.
Yes probably function of LCM but my cluster has gone backwards 20k. Thanks for replies and for the clocking service very interesting. Due to mine being high miles probably nearer 200k and his website says its only illegal if I don't disclose I will probably sell as is and info. FYI £90 quid and visit to Liverpool sounds routine, dangerous in the wrong hands!
