![]() | Home > Maintenance & Mods (L322) > Gearbox Megaflush |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
just wondering why engines dont get routinely flushed when the oils changed .... a lot of engines go on for miles and miles on just oil changes and i cant see gearboxs being different........ .... ... - .- -.
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473
Unnecessary quote removed
| EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361
That's true, on a FF it is going to be easier, but the main thing is circumstances. If it's at 150k, then the filter may or may not be worth doing, but if we're talking about a preventitive flush at 50-75k on a healthy box, then it will achieve nothing but waste fresh oil and add a little labour. Basically, the filter is only going to be "dirty" if the box has already screwed itself and needs more attention, so if the flush does the trick, there's no need to go further at that point.
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
Because the dry capacity of an engine is very, very similar to the service capacity As previously stated, a gearbox drain/refill replaces 4.5 litres, and the dry capacity is 12 litres (approx) You wouldn't drain only a third of your engine oil out on a service |
Indeed, why only do half a job, and only replace half of the gearbox oil? |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
So from that way of thinking LFW, if the engine oil is still clean (on say a petrol or LPG powered car) there would be NO benefit in changing the engine oil filter at service point? |
The engine oil is exposed to the products of combustion; the ATF is not. |
| Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217
As an aside , I had new sump/filter put on my car and did a couple of drain/refills .
| SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457
" If I were in the uk , I'd drive to a Zf service center in Germany .
I'm on my iPhone out on site , but will get you info as soon as I get back to the office .
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
This ZF service centre is not far from Calais....
| forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319
Is it worth getting this done on the S/C gearbox? |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
I can see the arguments on both sides but look at it this way, any engine or gearbox filter works one way, oil goes through it one way and the oil gets filtered removing bits of the combustion process in an engine, like carbon, and bits of the torque converter and clutches in an auto box. the filters are made so that even if neglected and used in extreme conditions they don't block up, they have a massive built in safety margin....
