![]() | Home > General > Which Range Rover |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
If you are not bothered about consumption why on earth would you not get a petrol.It is far quieter than the 'Tractor' Diesel ! |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
2007+ supercharged .
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
Coming from a Defender, you may find the performance of the TD6 acceptable - I found it dire - the TDV8 is significantly quicker & more torquey - you really need to drive both - but your budget its putting you well into good TDV8 territory - so the question should be more like can you stretch to a 4.4 or will you have to make do with a 3.6 |
Personally if your going up strata and thinking of any offroad stuff save money and get a td6 or SC under £10k.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
If MPG isn't much of a consideration, why are you reticent about buying a petrol model? Si. <This is my name.
CharlieBaja Member Since: 01 Feb 2016 Location: Surrey Posts: 52 ![]() ![]() ![]() |
I suppose what i really what to know is what kind of problems do you get with them and how easy are they to work on?
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
17 mpg combined |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
You are definitely into tdv8 territory at 20K, and performance wise that is the better option, its faster, torquier, and in the real world if not more efficient then at least as efficient as the td6.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
buy something like this
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
^ nice looking motor |
Looks half decent that. There is nothing that can't be fixed with a hammer😜😜
I would |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Black and a V8 3.6 Perfect. ( and not because that's what I chose ) 2015 4.4 AB
RidgeRover Member Since: 28 Jan 2016 Location: Dorset Posts: 21 ![]() ![]() ![]() |
I just switched back to a 4.2 sc after driving a Defender for a year (previously had a P38) so here are some thoughts from a recent convert:
