Home > In Car Electronics (L322) > Relocating aux input and 12v socket in facelift car
jonnyboy54321
Good day gents. Having done a search and not 100% coming up with anything - can I ask if anyone has done/could advise on the following please?
Our ff '07 tdv8 facelift has the phone cradle in the armrest. It's a Vogue non-SE so no rear entertainment.
In our previous car we had an ipod setup in the glovebox which was sleek and powered up automatically - I realise tha in the FF unless I spend silly amounts to do the LR install that isn't going to happen.
What I want to try and do is relocate/break into the aux port underneath the rear heated seat switches, and one of the 12v supplies, and install some cabling up to where the phone cradle is. So effectively have a 3.5mm port (or jack) and a usb port in there - that way I can stick Mrs JB's ipod in there and all I need to do is have her switch it on if she wants to listen through the aux input button on the dash. This of course could be used for her iphone/my android phone etc - you ger the drift. I don't mind some work to make a nice neat hidden cable solution - I hate trailing wires. I know our intrepid Mr Powell here (Hi David) is exploring a bluetooth receiver, but this was just a tangential thought of mine as the ipod won't do bluetooth...
Unless there is a better location? My glovebox is filled by a white-noise-only cd player, and a venturecam holder....
Cheers chaps.
Post #371631 10th Feb 2016 1:18pm
Best thing to do IMHO is run a cable from the glove box fuses to wherever you need it.
Use a piggy back fuse for the live & find a suitable earth point.
That's what the majority of people do for dash cams Thumbs Up
Post #371635 10th Feb 2016 1:25pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
If your CD player doesn't work , I'd look at the kit weegie just fitted and reported on a couple of weeks ago .
Or if you don't need/want all its features , it will be easier to tap into the port in the rear and the 12v in the center console .
Post #371640 10th Feb 2016 1:38pm
jonnyboy54321
I'll have a re-look at weegie's thread - I think I recall it.
Just wondering if anyone else had considered what I was proposing.
Post #371710 10th Feb 2016 8:26pm
ije44
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
I'd be careful about having 12v going directly through your USB jack. The standard USB convention is 5v at 2.1Amps. Putting 12v through your device will possibly fry it. You will need to put a DC to DC step-down converter before the USB jack to take 12v down to 5v.
Regards,
Ian
Post #371750 10th Feb 2016 10:50pm
Have you considered using a plug in Bluetooth transmitter with your ipod and then going down the Bluetooth route.
http://www.amazon.co.uk/Bluetooth-Transmit...ransmitter
Post #371757 10th Feb 2016 11:17pm
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
John
I'll try and find the thread that I've seen tonight.
Stage 2 of my install, will see me solder three wires on to the back of the aux in connector and add an additional connector into the armrest cubbyhole. There is already power in there so you can get away with a simple 12v adaptor although I'll be tempted to also wire in a couple of usb (with step down circuit) if I can find a way to mount them nearly.
Loving ally therefore although I'm planning to use Bluetooth you could skip that bit and go for iPod.
The biggest catch is I've read that that the aux socket is smart and needs a cut off headphone plug in it to make it work.
Post #371776 11th Feb 2016 8:43am
jonnyboy54321
David
This is most helpful, thanks.
Post #371788 11th Feb 2016 10:40am
jonnyboy54321
Embarassed
Was in the car today (I had an operation the day after purchase so Mrs JB has been monopolising it), and as David has indicated, there's a 12 socket in the lower armrest so all I need to do is lob in one of our wee usb converters like this:-
[/url]http://www.ebay.co.uk/itm/SILVER-UNIVERSAL-TWIN-2-PORT-USB-12V-DUAL-CAR-CHARGER-CIGARETTE-SOCKET-LIGHTER-/371448116046?hash=item567c08734e:g:DAYAAOSwKIpWA8Ps
I presume the phone cradle in there can come out - it looks removable but I am one-hand Larry at the moment!!
Then all I need to do is get the aux up into the armrest as a nice neat solution.
Post #371824 11th Feb 2016 6:00pm
davidjpowell
http://www.fullfatrr.com/forum/topic24633.html?highlight=ipod
John
The thread that I'm using. My test bed is working very well, so will be moving to stage 2 and integrating shortly.....
Post #372010 12th Feb 2016 3:05pm
jonnyboy54321
Thanks David, some good instructions for the aux-in relocation there.
I am struggling to understand one thing though.
Why bother with the bluetooth adaptor?
Example (based on relocating aux into armrest cubby) -
ipod - charge via usb 12 adaptor + ipod cable, plug aux-in cable into headphone socket on ipod
iphone - charge via usb cable as above, plug aux-in cable into headphone socket, leave bluetooth paired to car for calls
android phone - charge, play, call as per iphone
Is there something glaringly obvious that I am missing? If you want to be able to control the device it has to stay outside of the cubby/armrest of course.
Post #372016 12th Feb 2016 4:23pm
davidjpowell
I don't like wires that I can see Smile
It's (I) am that simple....
Post #372023 12th Feb 2016 5:58pm
jonnyboy54321
Would you see them if you put your phone in the cubby? Question
Post #372025 12th Feb 2016 6:02pm
davidjpowell
then I can't fast forward when my daughters one direction hit's the sound...
Eventually I'd like to end up with this... No wires, legal control....
Post #372027 12th Feb 2016 6:06pm
jonnyboy54321
Best get saving for the 250 euro kit that weegie fitted then !!!!!!
Mrs JB just had a go with an aux cable plugged into headphone socket of her iphone 6.
Works perfectly, phone call cuts in over it.
She's out in it at the moment (again.....) - is the 12v socket in the glovebox ignition or permanent live is my next investigation.....
Post #372037 12th Feb 2016 6:49pm
