Home > Technical (L322) > Power steering heavy
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
Hi all
Today when I started my tdv8 as I was in a rush (started turning wheel before engine had fully started) I turned the steering wheel which felt heavy I turned steering wheel again which was heavy -- I then got out of car and there was smoke coming from passengers side front wheel which cleared in seconds
I got back into car started and waited a few seconds before pulling off and now everything is fine I have driven all day today 50 miles and all is normal
Does anyone know what could have caused this
Thanks
Post #371769 11th Feb 2016 2:14am
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Was it colder or damper this morning than its been lately ?
This could cause belt slip which along with squealing can cause the temporary steering issues you describe .
Once everything warms up all is good .
Although the addition of smoke points to the belt running over a seized belt pulley or one of the accessories that belt supports (water-pump/fan , steering pump , and alternator)
If you were to take it to a specialist I wouldn't be surprised if they diagnosed the belt , belt tensioner , or alternator was on its way out ....
If your belt is old , you just got lucky Wink
You got a warning sign that hopefully will give you enough time to source all the parts needed mail order .
Buying for a future project is always cheaper than buying in an emergency Smile)
It costs around the same to buy an alternator , belt , and one idler pulley in an "emergency" as it does to buy alternator , pas pump , belt , 2 idlers , and the tensioner in "advance" ....
Labour difference is minimal to fit more moving parts on the front of the engine .
Post #371771 11th Feb 2016 4:22am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
N/s front wheel and smoke, could be the fbh, the exhaust is located in that area.
Post #371775 11th Feb 2016 7:09am
Benner91
Thanks for reply I'll get a look at replacing belts
Thanks
Post #371786 11th Feb 2016 10:31am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I suspect is Greg is correct.
FBH will emit some exhaust smoke in that area if cold. I see it quite often.
Turning the wheel at or even before complete start up will mean the power steering is not primed enough - After a second or two it should be so if you had no further problems I would suggest you were just a bit too eager to pull away. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #371792 11th Feb 2016 11:20am
