![]() | Home > Technical (L322) > Fan noise |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8767 ![]() ![]() ![]() |
Does the noise vary with speed, i.e. change in pitch according to speed, if it does it sounds like the tyre is catching on the inner wing somewhere...
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
check the dust shields on the back of the discs, they go rotten and touch the disc when turning, usual problem and definitely worth checking. |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
there's no change in speed which has me thinking of a fan I guess another session looking like i've been run over is needed L322 2008 vogue
Put the wheels on full lock both ways and the suspension in off road height, then get your head in the wheelarch, you should be able to see if the tyre is catching on something, it'll be the rear of the left arch or the front of the right arch... that's still my best guess... Pete
thanks ,snow and Rugby stopped anything happening today l L322 2008 vogue
