![]() | Home > Technical (L322) > Any one changed pixel ribbon??? |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
No... but you have my interest. Photos as you go please!
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Will do. AKspeedo.com and £24 notes inc delivery. Only had a couple in stock when i spoke to them though. |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
the trick is not to damage the connector where the ribbon is crimped as this is where your problem manifests lots of time you can undo this connection remake it and hey presto problem solved |
If the ribbon is crimped, how do you remove safely and replace effectively? Is it hard work getting dash pod out and striping to required level? |
removing the cluster is straight forward you have to be careful in dismantaling the cluster you will need to drill some plastic rivet heads out use an electric screw driver with a drill bit not a power drill when removing the ribbon use a hair dryer to warm it up to aid removal |
thanks for the tips. Not going to rush into doing this job if honest until sorted out other little probs. |
davemfox Member Since: 31 Jul 2010 Location: Chester Posts: 43 ![]() ![]() |
Me too ![]() Dave 1993 YZF 750 SP |
Hmmm, it's £90 for someone else to do it. I usually advocate doing things myself, but in this instance I think I would rather someone else took the risk.
Did you remove the needles or drill holes to access the screws? This was the very worst part of the job, as far as I'm concerned. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Think ill go this way when i'm ready to lose driving the car for few days. With the cluster out of the car for a few days i would like to keep the battery connected for the alarm, will this throw a fault? 2004 black Vogue TD6 |
Another thing... ![]() My mileage is sometime hard to read, is this a MOT fail? 2004 black Vogue TD6 |
This should help you |
yea have read that guide or similar.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I've just got in my car today, and the dashboard pixels have fixed themselves!!
