![]() | Home > Technical (L322) > Suspension - loud "pfffft". Now no suspension/no f |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8593 ![]() ![]() ![]() |
The clue is in the last sentence, you have a major leak somewhere, the poor little compressor can't keep up and switches off because it's too hot.. don't keep playing with it, that will just knacker the compressor, get it looked at and the leak found... |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
It seems to want to raise itself though. I don't know how to keep it from attempting it. It only seems to stop once I get the suspension fault but that's after a while of driving it. Each time I get in/start it, it tries to raise etc.
Air bags are servicable items like shock absorbers and springs, they aren't that much these days, and yes, front ones you have to change in pairs as they come with the shocks... rears are OK to do singly..
Yep, they are still doing it... front strut in the USA £211 same item in UK £374... not quite double but still a rip off...
Try not to drive it till it's sorted... |
I'm Not getting a specific code...How would I know for sure which one it is without taking to dealer. Each corner acts slightly different depending on the input mode.
No codes show, the system isn't that clever, get it as high as you can, turn engine off, and listen outside to the four corners, if you can't hear anything then it's out with the soapy water in a spray bottle....
We'll definitely the front. The rear is holding steady.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Unlikely to be faulty strut, that wouldn't put you on the bump stops (think strut=shock absorber, airbag=coilspring)
They are $600 for two remanufactured complete units
I'm assuming the oe Delphi units are better than the arnot ones. Are remanufactured just as reliable? 2014 FF Autobiography 5.0 SC
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
If they weren't any good Pete wouldn't have suggested them, if you read his posts he favors Delphi over Dunlop, but recommends Arnots'. I have the Dunlop fitted to mine, they work, but I'm not expecting them to last.....
I would need to have arnot struts though correct? You cant just replace the bags on OE Delphi front struts? If I can I would go that route. Everywhere I've looked so far just sells the strut with the bag for the fronts. 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
Haylands...mine is an 08 though. The link you sent for arnots was for up to 05 2014 FF Autobiography 5.0 SC
