Home > General > Violent wheel wobble when cornering at speed!!
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Normal bend on dual carriage way at 70-80 and got a violent wheel wobble. Backed of throttle and stopped??
Seemed to be when weight transfered to front left?
Also been getting susp inactive fault recently??
Any ideas? Would poor wheel balancing get a voilent wheel wobble or not??
Post #37219 20th Nov 2010 8:18pm
Yeah Thumbs Up
Post #37220 20th Nov 2010 8:19pm
dan_uk_1984
Would have thought as the weight lifted off the front right it was then free to have a wobble so maybe start there.
Post #37222 20th Nov 2010 8:27pm
Nickj
Not as easy as you think getting 24" alloys balanced. Went into kwikfit and they said they wouldn't fit the machine and recomended going to a lorry place! Not sure if i want to leave my wheels/car with a lorry place!!
After a quick google steering dampner came up? Is this a possibility or servo tronic valve.
It was a very violent wheel wobble. Felt like wheel may fall off!!
Post #37226 20th Nov 2010 8:37pm
24" Shocked Shocked YOUR STILL ON THE ROAD .....
Post #37227 20th Nov 2010 8:38pm
Nickj
Looks similar to your sig pic Thumbs Up
Post #37231 20th Nov 2010 8:41pm
dan_uk_1984
Perhaps your suspension doesnt like having bigger wheels than it was designed to have with a rubber band as a tyre?
If they are very low profile then you could have damaged the wheel bearings...
Dan
Post #37233 20th Nov 2010 8:44pm
I'm not sure the FF has a steering damper
Post #37234 20th Nov 2010 8:44pm
Nickj
I was thinking some sort of steering bush/rubber thats worn out as dosn't happen when cornering the other way eg transferring weight to drivers side. The large wheels may have accelarated issue but i still need to fix. Thers lots of RR running around on 22's with similar profile tyres!
Post #37238 20th Nov 2010 8:53pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
buckled wheel egde would show up more when cornering. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #37239 20th Nov 2010 9:00pm
There are two arms on each side at the bottom of the suspension which have rubber bushes. The bushes can be replaced but LR always tell you they are on back order, usually about 6 weeks, therefore the only other option is to buy complete arms.
Number 7 & 9 in this diagram
Post #37241 20th Nov 2010 9:08pm
Nickj
thanks. very useful diagram. Think booking it in for inspection is way forward.
Think wheels are true. I suspose swopping sides would eliminate this?
Post #37249 20th Nov 2010 9:37pm
elpeede
Go one better chuck it on the rear opposite side just to eliminate it if nothing else. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #37255 20th Nov 2010 9:50pm
Also get your steering control arms checked out. My drivers side was knackered (dangerous! according to tame mechanic). Caused violent wheel wobble / vibration at speed (German motorway) and when accelerating hard / up an incline. Other sign is having to hold steering wheel off centre to go straight. @ £70 fitted a side. .
Post #37300 20th Nov 2010 10:45pm
Nickj
Runs fairly true in straight line but guess getting suspension checked is best course of action.
I only get issue when turning towards right hence putting pressue on feft front side.
Although saying that do have wheel wobble (minimal and nothing like violent vibration discussed) when between speeds of 70-80mph.
Post #37311 20th Nov 2010 10:59pm
