Home > Technical (L322) > 2010 Range Rover 5.0 SC rattling
rkaad
Have a 2010 5.0 SV with high miles (170,000miles) with what I think is a timing chain rattle -- based on what I've gathered here. Question I have is has anyone had this rectified and at what cost or is this something that can be left alone?
Post #372560 15th Feb 2016 11:25pm
Fretless
Scotland 2011 Range Rover Vogue TDV8 Baltic Blue
Fix it fast, before something moves sideways on you !! The thought of that engine self-terminating... Shocked
The 'charger boffins will tell you to expect the wallet inspector, I fear it may involve some work to access... good luck Rolling Eyes The best 4.4 x far
Post #372564 15th Feb 2016 11:48pm
rkaad
Thank you.
Richard.
Post #372580 16th Feb 2016 6:24am
Beach
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Barolo Black
Timing chain is a about 15 hour job I have been told,these also get a noise from the supercharger snout. Mine is in being done under warranty it's got 60,000 miles on and I could hear a rattle/tapping noise.
Post #372597 16th Feb 2016 9:16am
funnyguy1
United States
I have a 2011 SC and had the same problem after I purchased it. It sounds like a diesel rattling away. I had it to the dealer 4 times. 1st time they did the chain tensioner update kit. Sounded ok for about an hour, then the rattling again. Took it back and the went at it again and 2 pulleys on the timing belt were not 100% aligned. They aligned. Bottom line, it still just rattles away. The dealer said its ok but I have listened to other 2010-2012's and they don't make the noise. Very frustrating.
Post #372651 16th Feb 2016 5:25pm
Beach
There is an updated SC snout that they checked out on mine and i still have the old part. I think they are going to do chains and SC. The tech who checked mine out knew the noise straight away as he had been to USA to work and theres rather alot of 5.0 SC he has dealt with.
Post #372658 16th Feb 2016 6:56pm
rkaad
Got the car back from the garage and the rattling has gone away but now have got the error "P0366-00 (E8 ) Camshaft position sensor B - circuit range/performance (bank 1) ". This came up at the garage and the the sensor was changed but error still cropped up. The garage have requested the car be run for a couple of days and then take it back for more diagnostics. The car will run for about a day without issue and then the error code will come back up -- resetting via IID tool gives me another error free day. Ideas anyone?
Thank you.
Post #381374 9th Apr 2016 6:03am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
May not be timed up correctly Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #381382 9th Apr 2016 7:58am
It is a known and common problem to the 5.0 SC - there was a dealer recall for this but only if you still have a warranty left on the car - otherwise it is a 15 hours job that you pay for - BUT if you don't care about the noise - there is no prob to leave it like it is - it wont damage the engine - that is what my local LR dealer told me when i had my L322 5.0SC. Neutral All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #381383 9th Apr 2016 8:15am
funnyguy1
United States
My Dealer told me the same thing but it sure is noisy. Sounds like a diesel but only when sitting still.
Post #381508 9th Apr 2016 8:52pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Mine sounds like a diesel at tickover too. Dealer says they will do it under warranty but I'm reluctant to let them do it in case it causes more trouble. I'm hanging on to see if it gets worse. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #381516 9th Apr 2016 10:00pm
There is an LR fix for this - no prob if done by an LR dealer.
PS. and yes it sounds like an Diesel ! Shocked All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #381531 9th Apr 2016 11:21pm
Nomad I would let them have a go. There is a workshop procedure for it, and if they follow it to the letter then there shouldn't be an issue. Thumbs Up Better getting it fixed now than after the warranty has expired. There is nothing that can't be fixed with a hammer😜😜
Post #381538 10th Apr 2016 12:09am
less expensive now too Laughing Laughing All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #381589 10th Apr 2016 10:13am
Nomad
OK. Might have to bite the bullet and get it done. Does it matter if I have the vehicle serviced at an Independent (with original parts) and then go back to the dealer for the warranty work? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #381591 10th Apr 2016 10:18am
