Home > Technical (L322) > TD6 over cooling mystery!
Page 1 of 4 1234>
sarn
England 2002 Range Rover Vogue Td6 Epsom Green
Having just replaced my TD6 main thermostat (as the Temp.Gauge had not moved above the 10 to position for the past six months) I was feeling some what smug as all returned to normal in the Temp. department. The Gauge climbing to mid position and staying there on a local 10 mile test run. Sadly my euphoria was short lived. Yesterday I visited Family which involved 150 miles on the Motorway. As soon as 60 to 70 mph was reached the temp. gauge started to drop and settled just above the Blue for the entire motorway part of the trip. Once back to trundling speeds (30 - 50mph) the gauge returned to the mid position and all seemed normal. Am absolutely at a loss as to what might be causing this problem. The Viscous Fan seems to be operating correctly (although it's impossible to check what's going on in the higher rev range). Could change the temp sensor and or water pump?! Any ideas please. . .
Post #372673 16th Feb 2016 8:18pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi sarn, my temp gauge never goes much past 10 to neither, it may sometimes reach 5 to but very rarely gets to 12 o'clock position, maybe only in the summer or uphills. I believe the egr thermostat maybe the problem as other's have had success when changing it.
Was going to have a go at mine when the weather gets better.
Post #372687 16th Feb 2016 9:45pm
^^^ +1 Thumbs Up .
Post #372696 16th Feb 2016 10:17pm
Discotigger
^^^+2 on the EGR 'thermostat'. Have seen quite a few threads on this subject so would be interested to see a definitive answer. My temp gauge is all over the place at the moment especially with the weather we're having at the moment, never gets above 1/2 way (12 O'Clock,) but in the summer it stays steady and the viscous fan runs (like a jet fighter's afterburner, or so it sounds!) when it gets above 2 O'Clock.
A real puzzle, but if the engine is running cool, is it a problem?
Post #372704 16th Feb 2016 10:47pm
sarn
Thanks guys but should have stated ERG thermostat and cooler system completely removed on my RR and exhaust manifold port blanked,along with relavent coolant pipes either side of the water pump.
Post #372712 16th Feb 2016 11:46pm
miggit
That is more than likely your problem, if you have removed the EGR thermostat and just linked the pipes together there will be a constant flow to the rad, if you still have the stat it might be worth putting it back in just to see if that cures it.
I haven't messed about with any of the EGR system other than removing the EGR it's self, and mine runs at a normal temp all the time. I'm not sure what symptoms a stuck shut EGR stat causes and whether it's enough to over heat the engine, but stuck open will cause over cooling Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372725 17th Feb 2016 12:58am
sarn
Hi miggit just to clarify I actually blanked off the two coolant stub pipes connected to the EGR thermostat / exhaust cooler. I would have hoped this would have the same effect as a permanently closed EGR thermostat. I did not make the mistake of linking them.
Post #372775 17th Feb 2016 1:42pm
miggit
Shocked In which case you is showing the signs of an open / missing thermostat Shocked
If an engine never gets hot then the only thing that can cause it is a defective thermostat, or something has bypassed it. Yesterday I couldn't spell Engineer... Today I are one!
Post #372777 17th Feb 2016 1:57pm
sarn
New main thermostat fitted - all fine running round locally,gauge at 12 o,clock. Only when I hit the motorway and wind it up does the temp gauge start to drop to almost in the blue. Once slowed down to B road speeds all fine again !!!
Post #372779 17th Feb 2016 2:40pm
miggit
Still recon it's the thermostat, as that's the thing that regulates the engine temp. I suppose that there is a possibility that the viscous fan has seized up and it's engaged all the time, that could be causing the engine to get over cooled at speed, but the thermostat should be able to compensate for that.
The way the system is supposed to work is the thermostat restricts the flow of water from the engine to the rad until the water is over 88, then it opens up letting the water in to the rad so it can be cooled. When it's dropped below 88 the thermostat closes allowing the engine / water to heat up again. It really does sound like yours has jammed open, possibly not fully, but open all the same. And it's restricting the water flow enough for the temp to get to 70 when there is little or no air flow through the rad, but at speed there is too much cooling being done by the rad and the temp drops. I realies that you have fitted a new thermostat, but just because it's new doesn't necessary mean it's working correctly.... I've fitted dud spark plugs before.... unless you dipped it in some hot water and saw it open and close there is no way that you can 100% say it's working Thumbs Up
And while I do recognise that it's a major source of Censored Censored Banging Head , it is however the most likely cause Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #372789 17th Feb 2016 4:46pm
I did give an uneducated warning about this over here: http://www.fullfatrr.com/forum/topic36076.html, which was shot down by others, but seem to have been proven right Rolling Eyes .
Post #372798 17th Feb 2016 6:38pm
miggit
But Wait, I have discovered more Shocked
There is another Censored thermostat.... for the oil.... it can cause under heating issues too
http://www.fullfatrr.com/forum/topic30370.html Yesterday I couldn't spell Engineer... Today I are one!
Post #372807 17th Feb 2016 7:17pm
Has anyone considered the fluctuating coolant temperatures experienced by the OP might be down to low coolant level or air locking of the system. The symptoms he describes are exactly what used to happen to diesel Discovery 1's when they suffered low coolant level due to leaking head gasket. Not suggesting head gasket is in any way leaking but the system appears to have been refilled after work on it.
Post #372829 17th Feb 2016 9:07pm
sarn
Thanks to everyone who contributed to this discussion - A lot to think about here with so many possibilities. Think the first thing I will try is swoping the main thermostat for a 100% original LR part, then leave off the viscous fan and test run the car under all conditions. If all ok will replace fan and re run test having made sure system is fully bled of air. Will report back in due course unless I have committed suicide.
Post #372862 17th Feb 2016 11:58pm
miggit
Just in case you didn't know there are 3 bleed screws for the coolant system, the header tank, the coolant rail and the EGR thermostat, D'OH!
Just in case you didn't know there are 2 bleed screws for the coolant .......... Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #372870 18th Feb 2016 1:23am
Page 1 of 4 1234>
