Home > Maintenance & Mods (L322) > Water in boot lid
Andy D
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Water in boot lid
Hopefully this is a really easy one to solve.
When I open the top part of the tailgate after it's been raining water pours out of it all over the parcel shelf. I'm sure this is something trivial like a blocked drain but I can't see where it is.
I've only had the car for a couple of weeks and it's my first FFRR so I'm still learning my way around it.
Any ideas? Thanks in advance, Andy '07 Supercharged in black with drug dealer tinted windows
Post #36008 13th Nov 2010 7:20pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I get this too... I once had leaf backing up the channel the tailgate hinges on. Clearing that helped. Other place of course that you can get water is from a leaking rear wash wipe as it goes through the centre pin of the wiper arm and backs up in the trim of the upper tailgate.
From your description it sound more like rain. I still get it from time to time. I suspect it is the volume of water running off the roof rearwards is to much for the drain so it eventually pools on the tailgate trim. Opening the tailgate slowly seems to help as the torrent then becomes a trickle and the splash is avoided.
Keen to hear if any one has any other soloutions none the less. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #36057 14th Nov 2010 3:43pm
InVogue
I have the problem too Sad Would love a solution to this...
Post #36064 14th Nov 2010 5:04pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
My old 4.4 (04) didn't have this problem but any rain and my 4.2 SC has torrents of water cascading down the channels either side of the rear window. It doesn't go onto the parcel shelf but I don't understand why on one it was a little dribble, on another it is Niagra.
Post #36072 14th Nov 2010 6:01pm
Fox
I thought this was a design fault.
Both mine have done it and when you have the light interior it's a real PITA as the parcel shelf gets stained. Sad
Post #36075 14th Nov 2010 6:20pm
elpeede
Out of interest are those of use getting the problem parking on the flat or on a slope?
My Drive slopes and generally the bonnet is upward and the tailgate at the lower end of the slope. I thought it would have been the volume of water for that reason. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #36076 14th Nov 2010 6:28pm
Andy D
Thanks guys, my drive is flat so it's not a slope thing. It's good though that it's not just me though, I just need to be really careful opening the boot in future '07 Supercharged in black with drug dealer tinted windows
Post #36079 14th Nov 2010 6:45pm
Fox
Not a slope thing in my experience, you just have to lift it up slowly.
It seems to get trapped somewhere and doesn't come out until the glass is lifted.
Post #36080 14th Nov 2010 6:50pm
InVogue
Yes, agreed, I have a flat drive too and it seems the only solution is to open slowly and carefully Big Cry
Post #36103 14th Nov 2010 8:49pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Another here, mine does it.
A problem shared is a problem halved... Smile 2004 black Vogue TD6
Post #36108 14th Nov 2010 9:03pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
4.4 - Did it.
4.2 - Did it.
5.0 - Does it.
Twisted Evil Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #36113 14th Nov 2010 9:14pm
The water that drips into the boot when the tailgate is opened comes from the edge of the glass, it seems to build up at both sides and sits there until you open the tailgate then it pours into the boot.
I wonder if a bead of silicon down each edge would cure it
Post #37285 20th Nov 2010 10:26pm
