Home > General > Front side lights
Page 3 of 4 <1234>
dubbs
United Kingdom 2007 Range Rover Vogue SE Supercharged Buckingham Blue
Ahhh..... yep, that'll be it, the ones that light as you turn Smile
Knew I'd not thought out all the possibilities - ta!
Post #37175 20th Nov 2010 6:22pm
Thumbs Up ... - .- -.
Post #37178 20th Nov 2010 6:32pm
Now its dark - here they are:
(OK, I cheated a bit by adding a bit of sparkle in GiMP), but these are sidelights, they're brighter than the headlights on my MG Midget! .
Post #37294 20th Nov 2010 10:37pm
they look like ufo's ..... Shocked ... - .- -.
Post #37297 20th Nov 2010 10:43pm
mzplcg
Looks cool. Would these units also fit the puddle lamps on the mirrors please anyone?
TIA
Dom
Post #37313 20th Nov 2010 11:01pm
Reformed
Just ordered a pair of these and looking forward to fitting them!
Post #37461 21st Nov 2010 3:39pm
you wont be disappointed mate. Thumbs Up ... - .- -.
Post #37463 21st Nov 2010 3:47pm
Reformed
Now fitted and a a big improvement, but what a mare to fit!
The bracket with the nut on the passenger side has been broken and bodged by the previous owner or garage!
After getting it out was straight forward but I have now got to repair the bracket, that said I will do a much better job than whoever did it before, a 5 year old could have fixed it better than that!
Post #38347 23rd Nov 2010 1:45pm
at least you sorted it now rather than in very cold snowstorm with hurricanes and tornadoes and thunder and lightening.....well you know what i mean..Laughing ... - .- -.
Post #38351 23rd Nov 2010 1:50pm
dubbs
Are the 2007-on easier or something? I simple undid 3 screws to the grille, three more for the headlamp unit and out it popped - easiest thing I'd ever done despite worrying it'd be a mare.
Post #38451 23rd Nov 2010 4:30pm
I don't think so. on my '02 its simply a case of undoing the plastic nut at the back and releasing the clip at the top front and you are done.
What seems to be the problem is that "past egits" have either knackered the nut at the back or it has disintegrated, or broken off the top clip, and effected less than suitable repairs - I must confess that one of my top clips is brolen off, neatly secured using a plastic zip tie. .
Post #38487 23rd Nov 2010 5:26pm
Reformed
It shouldnt be hard, just turn the plastic nut, and pop the light out to get at the bulbs, the other side was fine.
On the passenger side tho, the plastic nut was jammed on, and the bracket was broken. I am amazed it never fell out, the previous owner kind of wedged something behind to hold it tighter!!!
I had to fabricate a new bracket, and changed the rusty old bolt for the hand nut. Works a treat now, and is easy as it should have been, and is cheaper then a new headlight!
That said, my hands are sore now! Total time (inc fabricating new bracket) - 2 hours for a bulb change! lol
Post #38502 23rd Nov 2010 6:03pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Fitting on a 2006 with xenon
Changed mine to these...
http://cgi.ebay.co.uk/8-LED-SIDE-LIGHT-BUL...1922wt_827
Ok gentlemen,
It's the end of the week and my brain isn't functioning too well. From what i read the above side lights will fit a 2006 - but i cannot understand the bit about the canbus - should they be got with or without?.
If i fitted them will the lights flicker on ignition?
Stupid question i know, but thanks in advance
Cheers
oh bu66er, just tried the link to find "item removed".
So what lights can one upgrade to?.
Post #39541 26th Nov 2010 4:02pm
any leds/smds similer to the picture [my second post ] will be ok with canbus...dont worry about the flickering , its normal and wont do any harm..
Post #39542 26th Nov 2010 4:06pm
DavidP
Thanks Scarey, where can one pick them up/order them?.
Post #39545 26th Nov 2010 4:16pm
Page 3 of 4 <1234>
