Home > In Car Electronics (L322) > Infra. Red rear view camera
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
I bought this Infra Red rear view camera from eBay, the description said it would fit a 2011 4.4 Range Rover. Looking at the pictures enclosed, would you think this is a straight swop for what is on the car?
Post #372947 18th Feb 2016 2:21pm
wont be a straight swop..you'll have to fettle the camera and strip and rewire the cables.. ... - .- -.
Post #372952 18th Feb 2016 2:38pm
Cavalier
Thanks for that Stan, so there will not be plugs on the original camera, do you think, it will be just be a case of cutting the existing wires and fitting plugs to suit the new camera. I wonder if the existing camera comes out of its mounting and with a bit of effort the new camera will fit in its place. I am just trying to improve the rear vision at night a bit.
Maybe I should do a search: replacing reversing camera.
Post #372981 18th Feb 2016 6:19pm
miggit
Ian, if you need a hand just holler Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372985 18th Feb 2016 6:38pm
It's a different size & shape to the original camera - I would think that will be the most effort. You will also need to check the viewing angle.
Cabling should be straight forward - there should only be 4 wires - 2 for power & 2 for video. So use a meter to establish which are the power connections, then you have a 50/50 chance of getting the video the right way around the first time.
On your new camera, the red plug is power & the centre pin should be +ve Thumbs Up
Post #372989 18th Feb 2016 6:49pm
Cavalier
Thanks for that Alistair, the camera only cost £7, so I got it as a, might have a go at changing it some sunny day.
Thanks for the shout Migit, I will indeed give you a call when I decide to do it. Thumbs Up Sorry to read your resent mechanical problems you've posted recently
Post #373007 18th Feb 2016 8:34pm
miggit
It's all in hand, well a box at the moment, weather permitting all will be good this weekend Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #373028 18th Feb 2016 11:44pm
