Home > Technical (L322) > Error Codes
Mikey
Realist wrote:
Naa no issues at all apart from when I first had the car the dash screen said something about engine management but that cleared after a good run and someone said it could of been where the car was sat on the dealers.
How do I get to the hidden menus?
Ignore them then Thumbs Up
Post #373050 19th Feb 2016 8:22am
Realist
Wales
Thank you your a star Smile
Post #373079 19th Feb 2016 11:32am
Realist
Wales
Done just this tonight and the screen said 12.0v idle and when running its showing 13.5v.
So I presume that shows the alternator is ok is 13.5v to low?
northernmonkeyjones wrote:
put the voltage monitor on the nav screen on on the hidden menu, see what the alternator is putting out. It could be that your alternator is on the way out. It should be 13.5-14.5v when running.
Post #373201 20th Feb 2016 12:43am
The hidden screen menu is not even close to accurate sir... You need to check it with a volt meter now to be assured BUT........ In checking the hidden menu, you can be assured your alternator is doing something Thumbs Up
Post #373344 21st Feb 2016 9:34am
What Craig said, the alternator is doing something, however I would also now check with a volt meter across the battery terminals at idle and confirm the 12v. If it is only 12v then the alternator is dying. It should put out 13.5v minimum at idle, rising to 14.5 when it is charging after starting.
To check the idle figure, don't check it immediately after starting the engine, as the alternator will be trying to replenish the battery. Check it after you have been for a run out. That way the battery should be topped up and you will get a true reading. There is nothing that can't be fixed with a hammer😜😜
Post #373359 21st Feb 2016 11:27am
Realist
Wales
Tested with my multimeter tonight and at standing between the + and - it reads 12.0v and starting up, running lights, heaters everything to get the alternator to kick in and it reads 13.5v max.
So something is coming out of it but not enough so I'm under the impression that the alternator is Censored , great Sad
Post #373485 21st Feb 2016 11:02pm
Realist
Wales
Now who lives in South Wales and is handy at changing Alternators?
Post #373486 21st Feb 2016 11:04pm
Realist
Wales
Found a mechanic that can supply and fit the alternator for £435.00 is that cheap or expensive?
Post #373579 22nd Feb 2016 5:20pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
sounds on the expensive side, what motor you got?
Post #373580 22nd Feb 2016 6:03pm
Realist
Wales
FFRR TDV8.
Post #373582 22nd Feb 2016 6:09pm
lighthouse
no idea where it is on the diesel so can't advise on the effort required would have thought part would be around £200 mark
Post #373586 22nd Feb 2016 6:35pm
Very much doubt you would get a decent alternator for one of them for £200...
If your battery is only at 12V then it needs a good charge, it could well be that the battery has dies as it was sat at the dealers and it now won't take anymore than 13.5V
12volts on the battery is too low, should be 12.6 with it at rest...
Don't just change the alternator... give the battery a good overnight charge and then see what the readings are...
If the alternator is dying then they don't last long before they start smelling burnt and give up totally.... Then you have you confirmation... Pete
-Click here for Thread-
Post #373716 23rd Feb 2016 4:52pm
you can get a decent deal for these alternators Pete Wink
Post #373720 23rd Feb 2016 5:11pm
Blimey they have come down a bit in price... nearly as cheap as the earlier ones now.... Thumbs Up Thumbs Up Pete
Post #373722 23rd Feb 2016 5:14pm
Realist
Wales
Yeh that's about the prices I've been finding.
Post #373724 23rd Feb 2016 5:21pm
