Home > My Range Rover > Sick of my RR Vogue :(
Page 2 of 3 <123>
Remember to turn the steering full lock to full lock when the new battery is fitted
Post #37179 20th Nov 2010 6:35pm
typically the price has gone up since i brought one. now priced at £125.67 but still best buy..
part number is 444779008 ... - .- -.
Post #37181 20th Nov 2010 6:36pm
PJS
Thanks scarey!
What's the reason behind this?
Post #37183 20th Nov 2010 6:38pm
it resets the steering wheel perimeters [ or something like that]
btw , turn left and then right... ... - .- -.
Post #37185 20th Nov 2010 6:39pm
paneldamage
Could this not be a blower resistor issue? Or was it solved by the 2006 MY? I see a mention of a fan noise as if the fan is continuing to run.....
i am sure a more experienced member will come along and set me right. Could even be a combination of poor battery and this problem?
Post #37207 20th Nov 2010 7:06pm
I've been using Yuasa batteries for a number of years now, the oldest being around 6 years old and never had a problem with them. The last one cost me in the region of £67.00 + VAT and the code for the FFRR is 019T
Edit, just checking online and they are £117.00 Big Cry
Post #37247 20th Nov 2010 9:34pm
PJS
http://www.eurocarparts.com/ecp/c/BMW_5+Se...0&BATT
This battery?
Post #37248 20th Nov 2010 9:36pm
Try this link
Click the link and then click 017 then click the Varta equivalent for a price of £94.00 including VAT and delivery.
I've just checked my battery application guide and it should be the 017 battery Thumbs Up
Post #37250 20th Nov 2010 9:45pm
PJS
Are these good batteries then?
Post #37257 20th Nov 2010 9:51pm
Varta are one of the best Thumbs Up
Post #37259 20th Nov 2010 9:52pm
varta and bosch batterys are made by the same company called johnson controls...
the 017 type is only 95 amp hrs and 830 crank, the 020 type is more powerful at 110 amp hrs and 920 crank...
more here... http://www.fullfatrr.com/forum/topic2987.html?highlight=battery ... - .- -.
Post #37272 20th Nov 2010 10:03pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
And the 020 will NOT fit a TDV8, so I found out the other week Rolling Eyes
Post #37289 20th Nov 2010 10:29pm
PJS
Am i best to get the 20 then?
I had a TD6
Post #37308 20th Nov 2010 10:56pm
I had a TD6
the 020 is the best for a td6 ....[thats what i got] ... - .- -.
Post #37309 20th Nov 2010 10:58pm
@PJS
See my howto on battery disconnection
http://metricrat.co.uk/?p=113
Also, for removal, you will need to set the bonnet in mechanic mode by releasing the struts on each side .
Post #37318 20th Nov 2010 11:09pm
Page 2 of 3 <123>
