Home > Maintenance & Mods (L322) > Fluid leak
J90
France 2006 Range Rover Vogue Td6 Java Black
Fluid leak
Morning guys.
My TD6 L322 has just developed a fluid leak underneath the car at the rear of the engine bay.
It only drips this fluid when the engine starts.
The oil, ATF, brake fluid and coolant levels are constant and the fluid is clear with a very, very, very slight yellow colouring to it when on a piece of tissue paper.
The fluid has a slight odour to it.
The brake fluid reservoir has been overfilled by a mechanic when the front brakes were changed and it was my intention to draw some of it off to reduce the level.
Any thoughts what it might be guys before I toddle off to the local garage.
Thanks Travelling around in circles again.
Post #373088 19th Feb 2016 11:05am
J90
No warning lights have come on the dash either. Travelling around in circles again.
Post #373089 19th Feb 2016 11:08am
J90
I have just checked the car and fluids again and put a drop of ATF, Brake fluid, Coolant and Oil on a piece of tissue and none of them match the colour of the very pale coloured liquid that drips from the engine bay when the engine is started.
I'm now thinking a possible fuel leak?
Any thoughts anyone? Travelling around in circles again.
Post #373101 19th Feb 2016 11:42am
coincidence that this leak has appeared after the brake fluid overfill..i'd suspect that...
take a bit of brake fluid out of the receptacle and compare to the stuff on the floor.. ... - .- -.
Post #373105 19th Feb 2016 11:57am
If it's very pale and clean and oily then either diesel or brake fluid...
If it's diesel you should be able to smell it.... Pete
-Click here for Thread-
Post #373107 19th Feb 2016 12:00pm
J90
There is a slight smell to it. I'll check the Brake fluid odour and colour again. Travelling around in circles again.
Post #373110 19th Feb 2016 12:11pm
J90
Now looks and smells like diesel.
Now off to practise my french Big Cry Travelling around in circles again.
Post #373111 19th Feb 2016 12:13pm
Dolphinboy
"the fluid is clear with a very, very, very slight yellow colouring to it when on a piece of tissue paper.
The fluid has a slight odour to it."
Cat wee? (don't Laugh, there is a cat who cosies up some nights on my FFRR and leaves a little "Message") Whistle
Post #373138 19th Feb 2016 4:03pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Air conditioning?
Post #373140 19th Feb 2016 4:08pm
Looks like diesel
smells like diesel
probably diesel then.... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #373149 19th Feb 2016 4:33pm
J90
Diesel.
There was a split in two of the flexible pipes that the fuel runs through (not the clear ones to the fuel filter) I took it into the local 'Roady' and they fixed it there and then for the equivalent of £55.
I think thats a good price. Thumbs Up Travelling around in circles again.
Post #373175 19th Feb 2016 7:02pm
Can't moan at that...... Thumbs Up Thumbs Up Pete
Post #373185 19th Feb 2016 7:56pm
