Home > Technical (L322) > Help
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Help
Hi Guys help needed please, had the car cleaned today (all doors open for a couple of hours and the battery went flat!!!! had AA out and they have put on the in van diag on it (bosch) ad found everything working apart from the engine management not powering up and the only thing not showing on the dash is the EML. if anyone has come across this before and knows what i have to do or have done it would be a great help.
Russ If i could would you!!!!
Post #373172 19th Feb 2016 7:33pm
CS
When my 2004 car had a flat battery it would not start on jumpleads, we called LR Assistance who told the recovery technician what needed to be done. I wasn't on that part of the call, but I think when the battery gets to a certain (low) level the system immobilises itself, 'thinking' the battery has been disconnected as part of an attempted theft. The solution seemed to involve shorting out the system to re-set it, but I couldn't say exactly what was done. Try calling LRA 0800 521 786, they advised in my case even though I hadn't had LRA since the warranty expired over 4 years before, if no-one else can tell you what to do. Only Range Rovers since 1988
Post #373173 19th Feb 2016 7:50pm
cheers i will try If i could would you!!!!
Post #373174 19th Feb 2016 7:52pm
Sounds like a battery reset.
Have a look in the wiki. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #373179 19th Feb 2016 8:15pm
Battery reset will i find in the search If i could would you!!!!
Post #373180 19th Feb 2016 8:20pm
Here you go...
http://www.fullfatrr.com/forum/post67804.html#67804 Pete
Post #373184 19th Feb 2016 8:54pm
cheers! If i could would you!!!!
Post #373186 19th Feb 2016 8:58pm
Thanks for the info on battery reset but not worked, when I turn the ignition on I don't have eml? The car just cranks over and doesn't start.
What else could it be?
Thanks in advance If i could would you!!!!
Post #373250 20th Feb 2016 12:03pm
read the advice in the second post.. ... - .- -.
Post #373251 20th Feb 2016 12:20pm
Did you try the touching battery terminal connectors together (pos lead and neg lead when off the battery) trick to reset the ECUs ? Sounds like the same as "shorting the system"? .
Post #373254 20th Feb 2016 12:36pm
Yes I read the advise, and yes I touched the two leads together and the car is still the same. If i could would you!!!!
Post #373255 20th Feb 2016 12:47pm
An update on this! I left the battery disconnected over night and followed connection procedure and it started but the same has happened today it won't start just keeps turning over!! All the faults coming up ie: suspension inactive hdc dsc all staying on or flashing up in lcd. Just put a fresh battery on and still won't start. Disconnected again and will see what happens in the morning when I reconnect!!! If anyone has had the same issue please let me know.
Post #373737 23rd Feb 2016 7:25pm
Sounds like a possibly bad connection to the engine ecu or the battery is just dropping enough to cause an issue FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #373808 24th Feb 2016 12:37am
miggit
Just a thought, could it be a dodgy receiver / transmitter for the transceiver chip in the key?
And the other thing is what exactly did you have cleaned? did it include the engine bay? might just be a case of drowned ECU Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #373818 24th Feb 2016 3:41am
