![]() | Home > Duckworth Parts > Exhaust to manifold gaskets |
| Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354
Can you please advise the price and part number for the gasket between exhaust down pipe and the manifold.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
99.9% sure it doesn't have a seal, it's a dry joint... had mine apart when I did the gearbox... seals fine as it is... |
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217
As Pete said |
That is why I can't find them listed, thought I was going bonkers!
| SNR Member Since: 16 Mar 2016 Location: Northen Michigan Posts: 15
Not to sound like a wise guy but the NAS versions, or at least mine has it, have a "stub pipe" that goes between the manifold and the catalytic inlet pipe. It houses the upstream 02 sensor. I'm trying to find the |
I think I found a suitable replacement for this gasket. Mr Gasket header collector gasket #5971 matches the bolt holes. The OEM part has a 2 3/4" i.d. and this alternative has a 3" i.d., but it does mate up well. Tomorrow morning I'm going to finish this job and install these gaskets and I will share my results. |
