![]() | Home > Technical (L322) > TDV8 fault codes list |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I just stumbled on this and it might be of some use to all those who don't use the IID tool, |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Well I heard someone say there are thousands of things that can go wrong with that engine, I knew they were exaggerating.... there are only 999 fault codes.... |
I suppose that when you thing of the TDV8 has almost twice as many things to go wrong compared with my TD6, I thing I'll stick with my German Tractor.... apart from the French gearbox I think they are stronger |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
That list is for the Sport; would the fault codes for FFRR be the same? |
Yes it's for a sport, but it is a Land Rover product with a TDV8 engine, as I don't have access to any fault codes I'm unable to check....... but I would be surprised if they had invented a different set of codes for the ffrr, as that would mean bigger development costs, different software for the Testbooks, personally I can't see them being different, but I would check a few first |
Just had a look at the codes / another thread and the only fault code that begins with a P is P0562 - System voltage low , which the sport code has the same fault for the same code |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
P is powertrain (i.e. transmission etc. also), B body, C chassis and U are communications faults. |
