![]() | Home > Maintenance & Mods (L322) > Whistling brakes. Grease em up? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Mine did it for a while a few thousand miles after fitting them. Then just stopped.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
whistling brakes are happy brakes... |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
I'd have thought that putting grease on your brakes was not a good plan if you want to stop quickly |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Been running ebc greenstuff front/rears two weeks bedded in beaut on thes huge brembos |
![]() Cheers for the replies. ![]() |
Well, the 6 pot brembos are a bit different to the 4 pot brembos that were on the SC. There's a bolt bar type thingy in the middle, additional to the 2 standard pins. That momentarily flummoxed me when trying to slide out the pads after removing the 2 pins |
They are big! But fundamentally the same. I presume the big bolt through the caliper is to stop them spreading when you brake. |
