Home > Technical (L322) > Engine noises - normal?
AAH
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
After 3 weeks of thoroughly enjoyable ownership of my first FFRR (TDV8 2007MY) I am slowly learning all the little noises that come with it.
I have found when cruising on the motorway whilst maintaing a fairly constant speed (not accelerating) and the revs are sitting between 1900rpm and 2500rpm the engine takes on a slightly noisier and definitely noticeable tone/hum - this has nothing to do with gear changes or acceleration.
If you momentarily take your foot off the accelerator within this range the tone/hum stops even though the revs and speed dont really drop - the tone/hum returns as soon as you reapply your foot and a little bit of power. Under 1900rpm the engine is very silent and over @2500rpm although obviously there is more engine noise it does not have the same tone/hum.
I have checked this in manual mode and it seems to happen in all the gears.
Is this normal?
Thanks...... Angus
Post #37340 21st Nov 2010 1:16am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
http://www.fullfatrr.com/forum/topic3476.html?highlight=
Post #37345 21st Nov 2010 2:30am
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
My experience is that it comes and goes depending on the wind !!! I kid you not !!! I think mine is wind noise.
Not had it for weeks until yesterday with speed set at 100km , motorway turned a corner and it went. It did sound very gearbox like at first or even wheel bearing BUT as you say the box works fine, its not on one gear etc
Post #37364 21st Nov 2010 10:22am
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
i always have my stereo on and no problem noises.... Whistle 2004 black Vogue TD6
Post #37373 21st Nov 2010 10:42am
David
me to, then i blew a speaker !!!!!
Post #37374 21st Nov 2010 10:43am
AAH
thanks VMPP - sounds like the same thing
will just have to turn up the radio and then get irritated by a buzzing speaker
Angus TDV8 Vogue 2006 (2007MY) Tonga/Black
Post #38359 23rd Nov 2010 1:56pm
Dolphinboy
angus, buzzing speaker may be caused by corrosion on the pins in the connector to the amp in the rear left of the boot. I had that and took out the connecting wires on the amp, brushed them off and buzzing stopped! Be very careful if cleaning as the little male prongs are very delicate.
Post #38372 23rd Nov 2010 2:08pm
AAH
I think my buzzing might be a loose speaker housing vibrating or the sound making something else nearby vibrate
Post #38443 23rd Nov 2010 4:12pm
