Home > Technical (L322) > So! [iidtool]
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
So! [iidtool]
Apart from taking it out of the packing! And downloading the app!
What's the first thing I do, with my new IID tool BT...........................................
Answers on a postcard Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up 2014 vogue se
Post #373628 22nd Feb 2016 9:36pm
CY
2002 Range Rover Vogue Td6 Epsom Green
Check faults, clear faults, go for a drive... then check faults again!
Asides that, I had great fun playing with all the configuration settings. Stopped the retracting steering wheel (before it died) and enabled the 80s 'blip' noise upon locking/unlocking. Also enabled the daytime running lights using the dipped beam. Oh and heightened off road setting - will be useful at next week's SLROC green road run! Thumbs Up 2002 Range Rover Td6 Vogue
Post #373629 22nd Feb 2016 9:43pm
See what fault codes your car has recorded ?
Then clear them & see what comes back Thumbs Up
I used mine to turn of TPMS - but I had ongoing issues with TPMS....
Post #373630 22nd Feb 2016 9:44pm
chefkenmore
Think my wife suffers from tpms Rolling with laughter Rolling with laughter Rolling with laughter 2014 vogue se
Post #373632 22nd Feb 2016 9:47pm
chefkenmore
Mods
Thanks for putting this in the right place!
I'm not good at chess either Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up 2014 vogue se
Post #373633 22nd Feb 2016 9:49pm
chefkenmore
Where's the run Chris ?
Not that I can come! Caravan stuff to do before we go away! 2014 vogue se
Post #373634 22nd Feb 2016 9:51pm
check out what can be done here, select your model and enjoy,
https://www.gap-diagnostic.com/products/iidtool/
[Select your vehicle to see detailed functions] ... - .- -.
Post #373642 22nd Feb 2016 11:00pm
chefkenmore
Thumbs Up Thumbs Up Thumbs Up 2014 vogue se
Post #373677 23rd Feb 2016 9:20am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Have fun but be careful what you play with!
Whenever I feel like messing with something and I don't know exactly what I'm changing, I always recall this thread where poor Dave reset his gearbox calibration settings and it ended up costing him (although it seems most likely the fault was already present and being compensated for by the adaptions, removing the adaptions just highlighted it)
http://www.fullfatrr.com/forum/topic22497.html?highlight=adaptive 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #373688 23rd Feb 2016 10:45am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Be careful, I lost my Bluetooth and phone and still haven't been able to work out what the correct settings should be!!! Says it makes a back-up but mine didn't or at least didn't include all the settings. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #373896 24th Feb 2016 12:30pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
rej: PM on it's way! http://www.gap-diagnostic.com/
Post #373917 24th Feb 2016 3:20pm
Ironman1125
United Kingdom 2016 Range Rover Vogue SE SDV6 Barolo Black
Hi All. In respect of the basic IID Tool can it be used to reprogramme TPMS, i.e I have another set of wheels that I have put on, and I have each sensors ID. If not which version of the IID would be capable of doing this? Thanks
Post #390396 6th Jun 2016 1:17pm
GraemeC
New set of TPMS valves with automatically code themselves to the vehicle within a couple of miles driving (or at least the do for L322 versions!)
Only the spare should need programming to the vehicle (and I think you can just put it on for a couple of miles....) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #390398 6th Jun 2016 1:44pm
Ironman1125
Hi Martin, nah unfortunately they don't as I did three hundred miles yesterday with my new wheels and tryes and TPMS, if they are new sensors to the vehicle, you have to reprogramme the vehicle with the IDs of the new TPMS sensors. I spoke to the local dealership who spun me a yarn about having to remove all of the tyres to get the IDs, however further research has given me great insight and TPMS scanners are used instead as the local tyre did for me this morning and for free.
I think the actually scanner can update the ECI once it has the IDs of the sensors but the tyre fitter is new to the device and was hesitant. This is the scanner and even cheaper than the local dealer quote for the work. Not only that when I want to put the winter wheels back on you have to redo the process....grrrr
http://www.auteltech.com/autelcms/TPMS%20D.../403.jhtml
If this works it means I can do them each time myself Smile
Post #390400 6th Jun 2016 1:50pm
