Home > Technical (L322) > went in for oil change, came back out with AIR SUSP INACTIVE
Page 2 of 4 <1234>
CS
If the message is still coming up but the car seems to be working OK I suspect that one of the ABS sensors has failed. I think they can just do that at random times, so it could be a coincidence and not the workshop's fault. I suppose they might have knocked a connector out, or a wire has become detached. Only Range Rovers since 1988
Post #373765 23rd Feb 2016 8:40pm
Ohwhatalad
United Kingdom 2013 Range Rover Vogue SE SDV8 Corris Grey
hi thanks for the help yes the car all working fine as far as i can tell it just bongs when i get in and out and cant adjust height!
are the height sensors and ABS sensors easy enough to see? ill check that tomorrow too while charging the batt
Post #373770 23rd Feb 2016 9:36pm
If a height sensor was broken it wouldn't sit level and if an ABS sensor was out you would have a bunch of lights on the dash on from ABS to HDC to EBD...etc
If the car sits level with no other faults up then it is probably going to be something like the compressor or valves... little point looking around for faults as you won't see anything different...
Get the codes read and take it from there..... Thumbs Up Pete
-Click here for Thread-
Post #373775 23rd Feb 2016 9:49pm
holidaychicken
If they had it on a ramp with the wheels dangling down it can move the height sensors into a dirty part of their track and cause all sorts of problems.
Also battery drained as already mentioned after leaving it unlocked for a day whike they get around to changing oil and filter.
I kept clearing mine with allcomms and eventually it shut up.
I had DSC, ABS, EAS HDC inactive after my MOT and it kept trying to put the brakes on when I first moved off which is the HDC kicking in for no reason
Post #373795 23rd Feb 2016 11:17pm
Ohwhatalad
i had that, i didnt realise till i saw the tyre marks on my drive,
so thats HDC kicking in is it!
ill get onto the battery tomorrow, im hoping its just a bit low or something, then if not the IID tool will have to be ordered from dan. can always sell it after ive used it for a discount, i know ill need to get an unlock code!
then again, sounds like they come in handy Thumbs Up
Post #373796 23rd Feb 2016 11:23pm
holidaychicken
Mine would jam the breaks on and then go into fault mode and deactivate everything.
The fault code came back as an ABS sensor but they were new and I checked them and they were fine.
Depending on year, 2002-2005, the allcomms from RSW solutions is a fantastic bit of kit for the money and can read and clear faults and calibrate suspension among other things and was designed specifically for the L322.
Post #373802 23rd Feb 2016 11:57pm
A height sensor passing through a "dirty" area would be an "at the time" fault, as soon as it moved back it would not show a fault any more... The sensors are just a very cheap but reliable Hall effect sensor that is totally sealed, they don't get dirty inside...
After being raised on a two post ramp they can throw a hissy fit for a while but will usually return to normal after a short drive... Pete
Post #373809 24th Feb 2016 12:39am
holidaychicken
The theory is they drag dirt back into the used part and as you say mine cleared after a while but as always decent RR diagnostics is the key I have found
Post #373810 24th Feb 2016 12:45am
Ohwhatalad
is the allcomms from RSW a download and if so can i buy a generic usb obd2 socket reader and use it with their software?
just thinking what will be quickest solutions to getting these codes read and cleared and then have a tool for future use.
cheers Thumbs Up
Post #373893 24th Feb 2016 12:15pm
Phone Dan and he'll send you an IID tool next day... no great rush with yours, if the suspension is still at normal height... Thumbs Up Pete
Post #373936 24th Feb 2016 5:28pm
Ohwhatalad
Have pm'd him! just waiting for a reply so then ill phone and order one Very Happy
My front ride height is at access height, rear is normal, i think. hard to tell but in the daylight front definitely a bit lower!
didn't think it was the other night but then it was dark. ride seems fine
Post #373938 24th Feb 2016 5:30pm
Ohwhatalad
dan only has BT iid now Sad
Post #373947 24th Feb 2016 5:58pm
holidaychicken
cheers Thumbs Up
if you can find a genuine one in the uk you can use their software, (or find somebody who has one as they are not locked to a vehicle), i believe but you would need to contact them to check, there were some crap copies floating around ebay that won't work.
if not it's a case of ordering from the states which will take 2 -3 weeks at a guess but well worth the wait in my opinion.
i am a bit out of touch with what else is on the market but i do know the allcomss is brilliant and although i have a faultmate extreme i still use the allcomms more often
Post #374028 24th Feb 2016 11:43pm
Ohwhatalad
Thanks for the advice, i think as my car looks poo sitting so low i need something ASAP, i have found standard IID tool on ebay next day delivery for just under £300 so i think ill invest in that, just to get the code read and fault cleared to see if that does the trick.
shame your in kent or you could of done me a favour with your faultmate Rolling with laughter
Post #374029 24th Feb 2016 11:48pm
holidaychicken
I would gladly help out with the allcomms but the faultmate is vin locked with a €50 each way transfer fee.
I don't know about the IID but hopefully sorts you out
Post #374035 25th Feb 2016 12:40am
Page 2 of 4 <1234>
