Home > Maintenance & Mods (L322) > Terraclean
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Terraclean
Car going in tomorrow for its Terraclean, I have asked them to do a before and after Emissions printout. They say they always do a before, but told me there are too many chemical fumes present to get a true after test, straight after treatment, they tell me they will do the after test after I have driven the car for a couple of days.
Does this make sense?
Post #373785 23rd Feb 2016 10:11pm
smoke and mirrors.... Rolling Eyes Pete
Post #373788 23rd Feb 2016 10:21pm
Mikey
Waste of money, IMHO Rolling Eyes
Post #373793 23rd Feb 2016 10:59pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Slightly different thing but I had them do my sons DPF which had clogged irreparably according to the dealership who wanted £1600 for a new one but they did a terrific job. Completely fixed the issue and for a fraction of the price. I'd say in my experience they can certainly clean the internal workings.
Post #373804 24th Feb 2016 12:00am
Mikey
I done the same with a pressure washer Whistle
DPF was choked solid, and the car wouldn't run. Couple hours washing it out, took it for a blast to regen itself, with no issues
Post #373823 24th Feb 2016 8:12am
I tried it out of interest on one 100k TDV8 and was not impressed. It will not clean/fix faulty EGR's.
Post #373835 24th Feb 2016 9:51am
My "smoke and mirrors" comment was about their claim that they can't do a test straight after because "chemical fumes present".... what chemicals!!!! they advertise that it is super refined fuel that goes through the system, there is no mention that they use any other chemicals and indeed if they did you would have to capture and dispose of the exhaust gasses whilst cleaning...
Leave any car at fast tick over for an hour (which is what they do) will effect the emission anyway...!!!
A lot of the deposits in the engine that cause trouble have no connection with the fuel, deposits from EGR's are fed into the engine upstream of the injectors so even neat cleaning fluid will have no effect on them...
All Terraclean will do is clean the injectors and maybe remove a small amount of carbon from the intake valves... you can get the exact same result with a £5 injector cleaner from Halfords...
Do't believe all the hype from some tall bloke who doesn't cut his hair and wears orange gloves.... he has no engineering or mechanical qualifications, he's just an enthusiast who got famous when he made that motorised settee... Pete
Post #373941 24th Feb 2016 5:38pm
Mikey
As above, the "chemicals" smell suspiciously like Kerosene, which is the main ingredient in diesel injector cleaner Thumbs Up
Post #373944 24th Feb 2016 5:46pm
They do two versions. The one I tried went into the air intake system near the airbox and exited the exhaust......
Post #373971 24th Feb 2016 7:30pm
Mikey
I had the other, fuel system cleaner in through the HPFP and injectors
Post #373977 24th Feb 2016 8:08pm
Mikey
More to the point, what are the OP's thoughts Thumbs Up
Post #373978 24th Feb 2016 8:08pm
Cavalier
Well I had it done today, car is still running great, so I can't say I notice any difference. I am going on a 200 mile trip tomorrow, towing a caravan, so that will give me a better idea of any advantage, mpg etc.
I must admit I had it done, because I am only doing short stop start journeys.
I didn't like the misfire I had at the end of the last DPF regeneration, so if it happens again, I can say: I have had the top end cleaned up. If the misfire never reapears I can think the Terraclean solved the problem. Sheep Sheep Thumbs Up
Post #374012 24th Feb 2016 10:10pm
Cavalier
After running for about 250 miles since the Terraclean, I can't say I notice any difference to the running of the car. But it's a bit like my choice of diesel, I use Shell V power, thinking it is good for the engine. Others tell me it's a waste of money. Whistle
Post #374334 26th Feb 2016 5:44pm
