![]() | Home > Technical (L322) > Changed spark plugs... But one... |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Hi chaps,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35784 ![]() ![]() |
sods law is that if you try any more it will break and your heads will have to come off sooner...leave it till its warm and the suns shining... ... - .- -.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Is the ring the rubber from the inside of a plug socket?
@Stan: True that!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16386 ![]() ![]() ![]() |
Do you have access to a boroscope? You may get a clearer/closer pic with it? |
Unfortunately not. Considering buying one though.. Since they are not that expensive and always come in handy.. 2002 L322 V8 |
Thanks Jonny. That might just do the job.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Just be aware they have a thicker body than a normal socket. 2007 Vogue TDV8 with 255/55/20's fitted |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Those Irwin bolt grips are great, I have had a set of the standard size ones for ages and they work great. Those deep seat ones are new, not seen those before and look a good idea.
Have you got a photo of it taken at an angle because it looks to be something over it that's broken off flush with the cylinder head. I think it's a part of a socket that someones wedged in there and it's snapped off in a weird place. Is the surface smooth or rough?
Strangersfaces Member Since: 14 Feb 2016 Location: West, mostly Posts: 1 ![]() ![]() ![]() |
Take a good look at the spark plug attachment for this cylinder..., up inside, and compare it to one adjacent. Try plugging a free spark plug into that rear cylinder boot. I think you'll find the plug gripping part missing, and you know where it's gone. The metal part shown appears to be attached to the top cap of the plug, so your socket can't begin to reach further down to where it can grip the hex base. It's also unlikely that the plug wire will reattach properly and securely to that plug.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Definitely looks to me like you have something extra that shouldn't normally be there. Worth a shot with a dremel type tool with a carbide tip to make a bigger gap to yank it out with. Only do on a day you don't need the car, though.... |
Thanks for the thoughts guys!
Could be a previous owner replaced the plug coil cap when it broke off on the plug? .
