![]() | Home > In Car Electronics (L322) > Pin change |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
??? Bluetooth pin change???
Madmutt0 Member Since: 18 Feb 2016 Location: Bristol Posts: 78 ![]() ![]() ![]() |
Hi have a phone system in place at the moment but I believe I can replace the ulr module with a unit from a x5 bmw only some of the pins in the 54 pin plug need to be rearranged to accommodate the new ulr |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
just be aware that after you have done the pin change on the new unit you may have to re-flash it to work.have a look in the wiki for replace a bluetooth unit your instructions are there, |
Thanks will do |
