![]() | Home > General > Not a good start !! |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
If thats the response from the dealer then they are not a very good on in my opinion.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
"So what if I need to sit in it with the radio on for 20 mins...I have to leave the engine running ?"
RidgeRover Member Since: 28 Jan 2016 Location: Dorset Posts: 21 ![]() ![]() ![]() |
With the Consumer Rights Act 2015 that came in last year, within the first 30 days you have right to a full refund or repair if the car is faulty.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Wrong post deleted John
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8115 ![]() ![]() ![]() |
They are notoriously tough on batteries - the newer model L405 have two batteries installed.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
It takes longer than 5 hours to charge up a completely dead battery, more like 24 hours. So combine the charging time with the 70 mile trip (max 2 hours but probably less?), given the alternator will put out a high current fast charge but only on top of whats being used at the time and charging is not linear I would estimate the battery might have been half charged at the very best (also charging a low battery via the alternator will certainly not aid in it's longevity).
Come on what are these batteries about 800 aph so you could draw 800amps for 1 hour on a full battery, so half changed 400 amps for 1 hour, say he was using all the audio kit, all the light and it draws 50amps, thats still on a half charged battery a good 8 hours of usage.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Welcome to the FF world.. |
If only it was that simple! |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
I think I know what the dealer will say when I tell him it had the wrong sized battery fitted in the first place.. ' well thats what was on it when we bought it sir ". Proving otherwise is going to prove tricky. Still, the new one will be getting a run to Cardiff and back tomorrow. Should I do it in silence or put the radio on and risk needing a jump start to get me home !!
Should be fine to have everything running if it's a decent length trip |
I put the red connector on the pos terminal and the neg on that nut jobby they have near the top of the suspension leg as per owners manual. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
In response to Lighthouse the batteries are generally in the region of 90-100ah. And will deliver an instant cutter of 800 amps.
It somewhat depends on the claws of your clamps - you can end up with a fairly small contact area which will seriously restrict the current flow.
