![]() | Home > Maintenance & Mods (L322) > scuttle panel renovator |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35738 ![]() ![]() |
was it peanut butter?
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Stan. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8683 ![]() ![]() ![]() |
Peanut butter or any other oil will bring it up OK for as long as the oil stays on it or until the next wash...
this is a bit cheaper Pete, and you can have a sandwich after you've done the panel,
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Peanut butter |
The thing with the Gtechniq C4 Permanent Trim Restorer is that you do it once, that's it... job done... forget it for years....
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
+1 On the C4 Techniq. Great stuff! Costs a few quid but you only need to apply a few drops on a cotton pad. I did mine like 10 months ago and they are still shining bright. Will probably last years. 2002 L322 V8 |
Thanks for your help and advice lads?
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Hot air gun works a treat also as it draws the oils back upto the surface of the scuttle. Just be careful not to get it to hot |
Hi JPS.
