Home > Technical (L322) > Key fob battery fault
Phi.
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
A warning on screen said "key battery low"' I replaced the battery with new ones, still the same fault notice appeared. I have bought a further set to be certain the battery was not at fault but the same warning appears.
I have searched related post but I can't see that anyone has had a similar problem.
Please help!
Post #372012 12th Feb 2016 3:25pm
Brooksy
England 2002 Range Rover Vogue Td6 Baltic Blue
What brand batteries are you using ? I had the same prob. Got a battery from local motor factors, fitted it and still got same message.Then fitted a Duracell battery and worked fine
Post #372177 13th Feb 2016 5:10pm
Phi.
Hi Brooksy
Poundland specials- perhaps go get what you pay for!
Will try Duracell this weekend.
Cheers Phil.
Post #372202 13th Feb 2016 8:40pm
Phi.
Put new energiser batteries today- did the trick. Working fine now.
Thanks Phil.
Post #373600 22nd Feb 2016 8:00pm
dutchhome
United States 2009 Range Rover Supercharged 4.2 SC V8 Bournville
How are you guys swapping the batteries so easily? I only was able to change mine because I transplanted the guts to a new plastic FOB. I had to desolder the old battery and solder in a new one. Or does the UK have different FOBs than we do in the states?
Post #374298 26th Feb 2016 2:07pm
Phi.
Sounds like you have a different fob to UK spec. To replace the batteries take less than a minute.Plenty of how to videos to show you how they are fitted.
Good luck!
Post #374306 26th Feb 2016 2:49pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Once you replace the battery (2011 model, 2032 battery), you need to lock and unlock the car using the remote to clear the error message. Check YouTube for how to open up the remote 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #374350 26th Feb 2016 6:55pm
dutchhome
For reference, on my 2009 RR, I had to do something similar to these videos:
To get to the circuit board, it takes a lot of plastic wrangling:
https://www.youtube.com/watch?v=RM6SzJ3e4uE
Once out, I had to desolder the battery and solder in a new one:
https://www.youtube.com/watch?v=0YgpDWx-uH4
No, this is not me! I did have to mangle the old FOB in a similar way to get to the battery and PCB, but once inside I didn't abuse the thing like this guy does.
Edit: Typo.
Post #374361 26th Feb 2016 7:38pm
