Home > Maintenance & Mods (L322) > Windscreeen vibration |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 |
I had the same problem and i ended up replacing the plastic valance panel below the screen, it comes with adhesive to the bottom of the glass, i ordered it genuine and only cost $200 aus |
26th Feb 2016 10:26pm |
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 |
A bead of silicon does the trick as well. I removed mine, painted in satin black (still looks a bit rough as the plastic degrades in the sun) and reinstalled. Afterwards ran a line of silicon on the rubber lip, used some heavy objects to hold it down in the areas it had warped.
27th Feb 2016 5:06am |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
I had the same problem. My solution was to get some black exterior grade sealant and run this under the black plastic panel at the bottom of the screen, then bed the panel down into the sealant against the screen. No more problem vibration.
27th Feb 2016 9:32pm |
