Home > Wheels & Tyres > could this be repaired
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi all
So this week hasn't been great! and to top it off come out today to find a screw in my 2 month old £200+ rear drivers side tyre!!! Big Cry Big Cry Big Cry Big Cry Big Cry
Took the car to my local tyre repair garage and they have said that it is outside the allowed repair area and the tyre cant be repaired. Crying or Very sad
However reading online apparently you can get tyres vulcanised to repair them that are like this. Has anyone done this and if so does anyone recommend any companies? I know that I would have to send the tyre to them for a few days.
I wouldn't be putting the tyre back on as a main tyre as I will replace it but would like to get it repaired to replace my spare wheel tyre.
This is the tyre in question.
Any advice welcome!
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #374544 27th Feb 2016 5:29pm
I think they only repair the central 2/3rds of the tread area - so on that basis no
However, I had a similar one repaired on a previous car to use only as a spare - local tyre fitter that I know
The issue is apparently there is more flex nearer the sidewalls, so more chance of the patch becoming unstuck - I was happy to take the risk.
Most places are going to say no, but you might just find someone who will.
Post #374546 27th Feb 2016 5:38pm
no it cant Matt...theres to much flex at that point so the patch/mushroom will not adhere... ... - .- -.
Post #374547 27th Feb 2016 5:38pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
If you don't mind it letting go at just the wrong moment and writing off your car and seriously hurting your entire family, then skimp on the £200. letters not necessarily in the right order
Post #374548 27th Feb 2016 5:40pm
mattstevenson2005
just spoken to this company http://www.candstyres.co.uk/tyre-vulcanising/
they have said that they can do it and the repair will make the tyre fully safe and certified up to British safety standards, they will repair it and then bake it over night to cure the repair.
Got it booked in for Thursday £30, this is only going to be used as a spare anyway from now on so makes sense if they are warranting the repair.
Matt Current
Post #374551 27th Feb 2016 5:49pm
daveo
what about the original way they plug it with a rubber cord and glue, you have nothing to loose V8 facelift Range Rover Autobiography 22" wheels.
Post #374552 27th Feb 2016 5:52pm
fisha
Nothing to lose but the air from the tyre. Like the cord repair on mine. V8 or else ...
Post #374561 27th Feb 2016 7:37pm
proser
Had tyres vulcanised in the past and never had a problem Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #374583 27th Feb 2016 9:26pm
johnboyairey
You COULD look up a repair kit on eBay, and do the repair yourself, as its for your own spare etc. You get a sharp skewer tool and some rubber cords, for about £10. They are actually handy to have in the boot, in case you get the old 'oops just drove over an old mudflap in the road, and the upturned 'flap screws have just trashed both my near side tyres!' and I'm stuffed, and stranded. With the kit, you can get your tyres sealed, and a cigar powered pump will get them back up to pressure, all without even taking off the wheel! ( You keep some leak bubble liquid in the boot to reveal the holes)
It's true you should not rely on the (sidewall repaired) tyre for high speed evasive driving, like emergency lane changes.
But going around some back street east European tyre shacks, will get you into some vulcanised better repaired tyres.
Just saying what's out there, not recommending anything. Confused
Post #374611 27th Feb 2016 11:07pm
