Home > Maintenance & Mods (L322) > Front brake sensor - where to buy on a Sunday?
pld118
Hello,
Dismantled the front passenger brake caliper this evening to clean and greeze the whistling brake on that side in the morning and I think I've damaged the brake sensor as the plastic clip that fits onto the brake pad partially started to come apart... there are two pieces of fine silver wire partially visible (about 1cm) coming out of the insulated cable where it enters into the plastic clip.
Can you buy them anywhere on a Sunday for the RR?
Please/ Thanks.
Post #374572 27th Feb 2016 8:45pm
proser
Eurocarparts Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #374582 27th Feb 2016 9:22pm
Been there done that got the badge twice. If it clips in ok, and securely, refit it and replace when the shops open on Monday.
I broke mine in 2 and I couldn't find one so left the sensor off and refitted it on Monday. Some ECP are open Sunday's but not the one in derby.
Stripped the brakes on the disco on Fri as I had a wobble and replaced with a new set of LR discs. Wobble has gone, but this time I was careful not to snap the wear sensor! Gently gently prized it out with fingers and was careful not to bash or snap it There is nothing that can't be fixed with a hammer😜😜
Post #374598 27th Feb 2016 10:22pm
pld118
Thanks for the replies. Have put everything back on and no brake warning light which would suggest the sensor has survived and is still working despite looking a wee bit tired and fragile. I'll get a new one although maybe can fit it another day Whistle
Post #374642 28th Feb 2016 9:40am
If it ain't broke...... Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #374647 28th Feb 2016 10:04am
pld118
Aye, makes a change for me Alan... It's the karma of the new car Laughing
I shall bag myself a spare sensor... Just in case!
Post #374648 28th Feb 2016 10:05am
my near side front one is very tatty and i'm surprised it still works ..
did you put the paste on the brakes Ryan and has it solved the problem.. ... - .- -.
Post #374650 28th Feb 2016 10:15am
pld118
I had a tub of copper grease Stan and used that whilst waiiting to get the ceramic stuff. The whistling has stopped. The pads had obviously had some liberally applied copper grease on the backing before as there were gold circles from piston contacts... but no grease left anywhere. There's plenty on now though!
Post #374761 28th Feb 2016 9:28pm
nice one Thumbs Up
its surprising how that grease disappears.. ... - .- -.
Post #374768 28th Feb 2016 9:52pm
If you have alloy callipers, you shouldn't use copper based grease, apparently it will start electrolysis and rot your calliper... Pete
Post #374777 28th Feb 2016 10:17pm
