![]() | Home > Technical (L322) > Where do I start!!!!!! |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Re the brake fluid, it sounds as though you have a leak somewhere, burst hose, faulty caliper etc. If I were you I wouldn't drive it again until you find that problem and get it fixed. If you look around the vehicle underneath you should be able to spot the fluid leak.
gibbsy Member Since: 07 Oct 2014 Location: Stockport Posts: 11 ![]() ![]() ![]() |
Thanks for the fast reply.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8762 ![]() ![]() ![]() |
As soon as you start towing you put additional strain on it and any weakness will show up, whatever seal or pipe has failed was very close to doing it and the additional weight of the van tipped it over the edge..
