![]() | Home > Technical (L322) > GEARBOX D'OH!!!!!!!!!!!!! |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Well the ffrr isn't giving me many reasons to keep it |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
sorry to hear this Paul ,but i'm sure with your talents you'll figure this out.. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Can't think of much to check... how about the electrical plug to the box... you can "sort of" get it in place but in fact it's not... give it a pull and check it locked home OK...
At the moment I'm a bit stumped as to the cause, thought that it was a leak. The only solution that I can think of involves a gallon of petrol and a light |
Will give the plug a prod |
Hi Ed, the level's all correct, and it is new oil, the box was powerflushed on the Monday and the torque converter was changed the next evening, the car covered 4 miles max in between the oil change and the converter change. The transmission cooler is less than 17 months old, and was genuine, so I very much doubt that is at fault. And there is no way that the cooler is blocked as the power flush was done at the cooler return to the box, so all the oil has gone through it.
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
Thanks for the clarifications.
I can sort of see where you are coming from, I don't think that the powerflush did any harm as it was all OK after...And when I say powerflush I don't mean that it was plumbed in to a circulation pump, rather the return line from the cooler was disconnected and diverted to a can, new oil was added to the sump and then 2 lt's were run off with the engine running in gear, and then it was stopped and more was added until it ran clean. It was never run dry at any point of the flush.
Right so the plot thickens...........
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Hi Miggit,
Hi Steve,
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Sounds like the cost of the fuel would more than make up for the mechanical issues you're having |
Well I'm now totally confused |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473
Thinking aloud, could it be possible that the valve block is causing the TCC to be in a permanent state of partial lock, and it's become apparent with the new TC, whereas the old one had simply worn out as a result of a poor recon on the valve block that's now continued to get worse? It would fit but I don't know the valve block enough to be able to say if it's possible or not. |
| All times are GMT |
