![]() | Home > Technical (L322) > another battery down question ( sorry ) |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Battery should be about 12.5 v when engine is off and 14v when the engine is running and battery is charing.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
2 things to check...first is the alternator charge which should be around 14.5 volts on idle.....
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8065 ![]() ![]() ![]() |
Also - how old is the battery ?
Suggs Member Since: 16 Jul 2015 Location: Norfolk Posts: 94 ![]() ![]() ![]() |
not sure on the battery age as was on the car when i got it 8 months ago and just trying to find a bill for it..
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Sounds like the alternator is OK, over 13.5V is considered OK. It will vary depending on load and rpm.
thanks again, i took it for a drive yesterday and the battery was showing 12.2 volts before i started the car then 14 v at tick over. i drove for about 10 miles and when i got back battery was showing 12.4v engine off, this morning its showing 12v engine off but its been very cold again here over night.
If your only getting 12night after a drive its time for a new battery. |
@suggs, a fully charged battery should read 12.6 volts, yours has 12,4 so its not far off....i should think a longer journey or a bench charge should be enough... ... - .- -.
Thanks for the tips folks. im going to stick it on a long charge and monitor the voltage, and order a new battery |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I've decided it's just part of ownership. Mine didn't start on Sunday after a cold night and not being used for 3 days. Put it on charge for 6 hours and it was fine. I've learnt to live with it....on a plus side, was away with tintent the wknd before and the Japs/Koreans got stuck.....I didn't and took it with grace and dignity |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 151 ![]() ![]() ![]() |
Do we charge with battery connected or leads off ? and excuse my ignorance but what is HDC ?
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
You can leave the leads on, just make sure the ignition if off.
Ah now I'v got it, Thanks. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
@Suggs
