Home > Maintenance & Mods (L322) > L322 Update/Upgrade
The IIDTool has an update for the Bluetooth module. Got - 2017 SDV8 Autobiography in Loire Blue
Post #375166 1st Mar 2016 8:35pm
Realist
Wales
Thanks but I don't have a IIDTool.
Post #375168 1st Mar 2016 8:41pm
Good reason to buy one then Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #375169 1st Mar 2016 8:41pm
As does the faultmate and sdd units. But if you want to upgrade it I'd say it's worth doing the 2010 and I've done both so know what I'm on about 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #375170 1st Mar 2016 8:41pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi kp, sorry for hijacking the thread, is the d4/rrs module plug and play, cus I have the nokia bt module that can't be updated. Big Cry
Thanks greg. Thumbs Up
Post #375176 1st Mar 2016 8:57pm
It isn't what most would call plug and play but if you can cut two wires and strip the plastic back from them then it's easily DIYable. I've done a few members before but with work being as it is at the minute I haven't got much spare time anymore.
There is a guide I think in the WIKI section on here Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #375179 1st Mar 2016 9:00pm
DSCOOPS
England 2006 Range Rover Vogue SE TDV8 Barolo Black
Dijit wrote:
miggit wrote:
Clean the EGR valves or get them bypassed Thumbs Up
Am not aware that you can bypass the EGR valves in a 3.6 or 4.4 TDV8. Can anyone put me right please?
EGR'S can be switched off in the ecu. Just had mine done. I think then you can physically blank them but haven't seen any blanking plates for sale. You can get the egr patch for the iid from bas.
Post #375195 1st Mar 2016 9:33pm
Realist
Wales
What does the switching off the EGRs do to the FFRR and why do it?[/s]
Post #375198 1st Mar 2016 9:37pm
DSCOOPS
The switching off stops the egr valves opening preventing exhaust gases being mixed with fresh air back into the engine - this being a method to minimise emissions by reburning exhaust gases. Problem being that exhaust fumes are dirty and clog the valves meaning they get stuck and stay open when they shouldn't.
Post #375200 1st Mar 2016 9:44pm
miggit
^^ then they clog up all the inlet side of the engine, and I suspect that they cause the back pressure to climb to a level where the turbo says "sod this I'm off, BANG Shocked " That is purely speculation.... Whistle but I have heard more than once that turbo failure is due to blocked / malfunctioning EGR valves Whistle
Its either that or they save all the carbon up and dump it in to the engine in one go, taking out the turbo as it all goes Rolling Eyes As they say, I know nothing Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #375224 1st Mar 2016 11:32pm
Realist
Wales
So is it better to leave as is or get them mapped out or removed/blanked?
Post #375237 2nd Mar 2016 12:51am
miggit
If you get them mapped out, they will stay shut, which will not dump a load of muck in to the engine and risk the turbos. I'm not totally up to date with it all as I have a different system on mine (TD6) but I have seen a lot of posts saying that the turbos and the EGR's have gone, but you don't see many where it's just the turbos.
I did read somewhere that the turbos were reliable and rarely fail on their own, and it was the EGR system that causes all the problems. I know that the TDV8 has a reputation for splitting the induction hoses, between the turbo and the engine, Whistle well the bit of the engine that the hoses connect to are the EGR valves Shocked And it equally has a reputation for eating the turbos.... but I recon that every failed turbo has got a blocked EGR valve behind it. The only other thing that could take out the turbo is a failed oil system and I haven't read anything about that Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #375242 2nd Mar 2016 1:58am
rar110
The real problem seems to be crank case ventilation entering after the EGR inlet. Oil vapour combines with soot in the exhaust gas to make a gooey mess. I'll try to post a pics from the WSM.
BAS advised me they don't do an EGR map out yet (even though on there website) for my tdv8 without a DPF.
 ______________________________
Post #375243 2nd Mar 2016 2:34am
gregdav
Hi kp, thanks.
greg. Thumbs Up
Post #375247 2nd Mar 2016 8:06am
