Home > Technical (L322) > P0174
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
P0174
Anyone know what could be causing P0174 errors to keep coming back, also getting it for bank 1 as well sometimes. Happens on both LPG and petrol so have ruled out the LPG system.
I have changed the plugs to affect.
Ideas please.
Post #375262 2nd Mar 2016 10:39am
done a forum search and that code is mentioned in the following threads,hope it helps,
http://www.fullfatrr.com/forum/search.php?...rch_time=0 ... - .- -.
Post #375264 2nd Mar 2016 10:43am
dingg1
lean code , most likely unmetered air entering somewhere , best guess would be at breather hoses on either side of engine , the one on the drivers side can be most problematic IME .( crap design and slack o ring )
could also be slight sticking of LPG injectors , happens every winter to me and a squirt of my own made up solution of wd40, 3 in 1 oil, thinners and easy start , down the lpg hoses does the trick.
could also be dodgy MAF.
you 100% sure its happening on petrol as well?
ie have you run her for 4 or 5 times on petrol only and see if the codes return after clearing?
Post #375288 2nd Mar 2016 12:09pm
lighthouse
which hoses are you talking about?
Post #375289 2nd Mar 2016 12:11pm
dingg1
stand in front of car , remove engine cover , look left at top of engine theres a breather hose that clips into a corrugated type hose listen for it sucking air , theres a smaller breather hose on the other bank check that too.
down load some info on the engine to see diagrams
Post #375291 2nd Mar 2016 12:19pm
lighthouse
can't seem to find any diagram of the engine its not on rave
Post #375292 2nd Mar 2016 12:22pm
it wont be on RAVE, rave is for 2002-2005....... try the 2006-2009 WM... ... - .- -.
Post #375298 2nd Mar 2016 12:32pm
lighthouse
i Am being stupid. WM? Do you mean workshop manual, I will have to try and find a copy.
Post #375309 2nd Mar 2016 1:18pm
Here you go, it's in the WIKI...
http://api.viglink.com/api/click?format=go...VNfUHlXRUE Pete
Post #375310 2nd Mar 2016 1:31pm
lighthouse
thanks
Post #375311 2nd Mar 2016 1:41pm
